Question about Zanussi 23 in. ZKT641H Electric Cooktop
Left hand side not working
When I turned on my Zanussi hob the other evening, alongside the control panel red lights starting flashing and now the large ring does not heat up although the panel button still works and the top left hand small ring does not do anything. What could be wrong before I blindly ask a repair engineer to call.
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
Posted on Jul 16, 2009
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Right hand side of hob flashing reverse 9 or p inop on t4343 other side of hob working ok
right hand side hob not working. Flashing on and off with a sign that looks like a reverse 9 or P maybe?
Feb 28, 2011 | Neff 23 in. T4343 Electric Cooktop
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
Boch ceran 9000179011 try to turn on and red light flashes on right hand side of touch controls
Did you ever get a solution to this? My Bosch hob is doing the same wanted to know how to resolve or if I need to call out a technician.
thanks.
Sep 13, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Zanussi 23 in. ZKT641H Electric Cooktop Logo
541 people viewed this question
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
