Question about Fuji FinePix F610 Digital Camera
Fuji finepix f610
When I swap the main battery I lose the date, time & image settings. Presumably there is (or was!) an internal back up battery. Is this so and is it replaceable?
  • Anonymous Dec 10, 2008
    If anyone knows what to do let me know.
    Also, if you know where I can get a users manual I would appreciate it.
    Someone one gave this camera to me without it.
    Thanks
    Lillliam
  • 3 Answers
If this is like the F410, there's a soldered back-up battery on the flexi-pcb connected to the power socket.
Posted on Apr 21, 2009
No backup, just re-set the time and date as prompted when you turn the camera back on, it takes 1 minute....!
Posted on Nov 23, 2008
Why do I lose date/time on Fuji FinePix S6500 digital camera when I change batteries
You lose the date/time because the camera has no power to it to keep the settings. Basically don't leave the batteries out if you want it to keep the date/time. On the other hand it will just sit and run the batteries down just sitting there off. It is a bit annoying but that's why. Most cameras store an internal charge so they can keep the date/time but it is not supposed to last very long, it was designed so you could swap out dead batteries without having to reset the time/date every time. If it is happening on simple battery changes it means something may be wrong with the camera.
May 17, 2011 | Fuji Finepix A510 Digital Camera
My Fuji Finepix S5100 camera keeps losing its settings and date and time when the batteries die. Is there a small "watch" type battery that can be replaced so it can keep its memory?
There is no "watch" battery in the camera. Always keep fresh batteries on hand and switch them out quickly. That usually solves the problem.
Mar 08, 2011 | Fuji FinePix S5100 Digital Camera
I have a Fuji Finepix S7000 digital camera. I works fine, but, when the batteries get discharged, the camera looses all the "setup" info (date, time, etc...)... Is there an internal battery or something...
There is no internal battery. When the batteries become discharged or removed, the camera retains the date/time settings for about 24 hours. Most people have backup batteries fully charged so when one set is low in the camera, they can make the change quickly.
Feb 28, 2010 | Fuji FinePix S7000 Digital Camera
Fuji E550 loses date and time every time i change batteries
Theres a small back-up battery located on the main
power board. It's not a DIY project to replace this battery.
Feb 17, 2010 | Fuji FinePix E550 Digital Camera
Every time I replace the 4 AA batteries all camera
There is an internal battery back up for storing settings. It's soldered to the main board and I don't think it's a rechargeable battery judging by the amount of people who have owned these cameras who have encountered the same problem.
It's a watch type battery and these things do go flat after a few years and unless you know the type and voltage only fuji service centres can replace.
It won't affect the camera's performance it's just a pain having to set up each time you change the batteries.
Jan 18, 2010 | Fuji Rod Repair Kit
Is ther an internal battery in my fuji s 7000
yes. usually soldered on to the main board. Goes flat after a few years and camera will not store date and time or any of your settings when you take the batteries out
Dec 12, 2009 | Fuji FinePix S7000 Digital Camera
Hi, Every time I change the batteries now, I lose my time,date etc settings.
I don't have any experience with a fuji but I do believe it has a small internal battery that keeps just enough juice to operate things like date and time. I would take it to your local camera shop they will stear you in the right direction if not make the repair for you.
Oct 17, 2009 | Fuji FinePix S5500 Digital Camera
Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Sep 28, 2009 | Fuji FinePix S9000 Zoom Digital Camera
When battery is changed date and image size need resetting
Internal battery or capacitor may be bad and not holding charge to keep settings.
Oct 20, 2008 | Fuji FinePix F700 Digital Camera
Fuji Finepix 3800
The date time problem ist he internal battery[ A watch type button inside the camera body]
has worn out- replacing it will be a workshop job.
The other problem seems like wear and tear on the switch any repair will be costly.
Just live with[out]it- or buy a new camera
Nov 20, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji FinePix F610 Digital Camera Logo
203 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
