When volume button is pressed on remote it goes as loud as it can or down to zero if turning volume down
  • bakerman1 Sep 16, 2008
    The problem is there is no in between it either goes up to level 99 or down to level 0
    The tv is only two months old but maybe a faulty part, I was hoping it was a screwed up setting that way I wouldnt have to haul it in
OH OK your vol control which is a contact switch is either dirty or bad, you may want to order new front panel board the one that has on/off vol+ vol-ch+ ch-
Posted on Sep 16, 2008
  • 5,138 Answers
So WHAT IS YOUR PROBLEM?
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
I have a curtis flat screen and when i turn it on the volume automatically goes to zero. I press the volume to turn it up but it just goes back to zero. I press the menu button and it just cycles through...
Take the batteries out of the remote and turn it on manually see if that helps............ you might have a stuck remote.
Also make sure none of the buttons got stuck in the pressed position......
May 18, 2014 | Televison & Video
When I switch on my L24FED13 I get a speaker icon in top left with zero next to it, the remote does nothing after switching on
Sounds like the remote or the receiver may be faulty. The speaker icon with the zero means simply that the volume is turned down to zero.
When you press remote buttons, do you see a flashing light on the screen at all? Can you use the buttons on the screen itself to try and adjust the volume? You'd need to try these things first, so we know how to help you further.
Oct 28, 2013 | Computers & Internet
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
No volume without holding remote button
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Sep 24, 2009 | Televison & Video
Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Jun 14, 2009 | Vizio L37 Television
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
