Question about GE Spectra JBP78 Electric Kitchen Range
GE Spectra Dual Burner not working.
The outer ring of my dual burner does not come on any more. When we turned it on this morning, we heard a click and it would not come on. The middle part comes on and works fine, it's just the outer ring. Is this something I could fix myself or do I need to call someone? I have the same problem but it is the smaller element that does not come on. Where can I find a reasonably priced replacement part?
    Sergeant:
    Champion:
  • 331 Answers
The burner is faulty
replace just the upper part of the brner
or try to clean it
yourself
Posted on Sep 16, 2008
  • 1,029 Answers
Since its just the outer ring thats not working and needs to be replaced you can order for the parts with the model/serial number of your burner and get it fixed but that will be best done by a technician ,
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
My large burner does not heat up fully...the outside ring does not heat, only the inside, is this a fuse issue and where do I find the fuses?
The problem with that is going to either be the outer ring of the burner burnt out OR the control sitch for that burner. THier is no fuse for the burners, the switch for that dual burner is part number 74003122,the part the dual burner is 12002144
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Aug 15, 2011 | Maytag MER5870 Electric Kitchen Range
Dual top burner will only heat up on high.It is only the large ring burner GE JBP79
Does it go straight to full heat even though it is on the low setting. If this is the case the hotplate controller is faulty and requires replacement.
Feb 24, 2011 | GE Spectra JBP78 Electric Kitchen Range
My GE profile electric range (model PS905SPSS) has a power boil burner with dual burner elements (one inner circle and one large outer circle). The outer circle one is glowing and heating but the inner...
Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
Nov 27, 2010 | GE Ovens
Small burner of dual surface(right front) stopped working.
Does yours have the (small large burner switch)? If so, try switching it back and forth. It could be defective or your small burner element is bad.
Mar 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
HOW TO TURN ON OVEN
I found an Ad with a description of the burner knob operation. Unfortunately I found nothing on the oven knobs. However, it's possible that the oven knob operation is similar to the burner knobs... * Dual burner operates by pushing in knob once for inside ring only (1,000BTU) and pushing in again to activate the outer ring (total 16,000BTU) Hope that helps!
Jul 30, 2007 | DeLonghi DEFSGG36D-SS Gas Kitchen Range
CAN NOT TURN ON OVEN
GE Spectra JBP78 Electric Kitchen Range Logo
231 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
