Question about Maytag MMV5000 Microwave Oven
Broken microwave my maytag microwave is unresponsive to any keypad selection and has the letter D on the display.
Microwave oven goes for 5 seconds then stops? Any suggestions? Thanks,
Ward
Posted on Nov 17, 2008
  • Maytag Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then please let us know if the hard reset does not fix it.
(It may need work on the controller or keypad)
Posted on Sep 16, 2008
5E display on maytag microwave
<- Let me know your full model number from the tag on your oven so I can give you detailed information repair.
Unless there is grease or moisture on your control circuit board, "SE" means you have a shorting membrane keypad.
Jan 05, 2014 | Maytag MMV1153A Microwave Oven
My Maytag Microwave is blowing the 250v- 20a fuse behind the key panel on the black wire. It melted the fuse holder mounted to the main body of the unit. Any thoughts on why?
The magnetron is shorted, the keypad control board is bad, blowing fuses. If less than 7 years old it has a inverter board that can be trouble, But with the level of work and parts it will easily exceed the cost of a new microwave oven.
Apr 07, 2012 | Magic Chef CMV1100 Microwave Oven
MVP V Model CMV1000ADW
From the description it is the keypad control board problem, membrane "shorts" replacement only option.
Apr 04, 2012 | Maytag Appliances Over-the-Range Microwave...
Screen displays -SE- , none of the keypad buttons work
The word -SE- , means systems error, the cause is a short in the membrane of the keypad. The only solution is the keypad must be replaced.
Mar 05, 2011 | Maytag Appliances Over-the-Range Microwave...
Display and touch buttons inoperative on MMV4205BAW Microwave Oven. Only abt 2 yrs old...
The keypad controller has probably developed a short in the membrane of the keypad, it must be replaced in order to get it up and running, but I suggest a maytag repairman to address this.
Feb 21, 2011 | Maytag MMV4205 Microwave Oven
My chefmate 1050 watt microwave beeps nonstop for minutes at a time repeatedly. I must leave it unplugged to get relief. Also, the keypad is unresponsive sometimes.
Either the touchpad or control board is defective. If the ribbon cable was disconnected from the control board and the beeping stops it would confirm the problem. Since the keypad is unresponsive, that probably is the problem.
Jun 21, 2010 | Microwave Ovens
Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Dec 17, 2009 | Kenmore Microwave Ovens
GE Spacemaker Microwave display is flashing. Keypad is unresponsive. Boiled water for a long time under the unit. Person attempted to operate microwave. Loud boom and then this. There is a smell of...
Microwave is 16 years old. Replaced it. Service call was going to be half the cost of a new one with no assurance that problem could be fixed once it was diagnosed.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5000 Microwave Oven Logo
644 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
