Question about Kenmore 15899 Built-in Dishwasher
Black specks There are black specks on my dishes (on the bottom of cups and glasses mostly) after the cycle is complete. My dishwasher is 12 years old. Dishes are otherwise clean. Thanks in advance.
  • djagh Oct 21, 2008
    I get "crud" inside my glasses on the top rack. I've had Sears come out but they never really solve the problem. The DW fills, heats, drains and drys with steam so it seems like it's functioning properly. What would cause this? Kenmore dishwasher 665.1899100.
    Thanks so much!
  • Anonymous Mar 13, 2009
    I have same problem that started a few weeks ago. Can wash and rewash the dishes multiple times and I'm still getting this. Could it be something in the tap water? Something coming from water heater?
  • 530 Answers
Is that a glass? can't tell. is there water curculating to the top rack? if not you probably have a bad chopper
Posted on Jan 06, 2009
My dishwasher is about 4-1/2 years old. Lately I am getting a film on my dishes especially glasses. I use Finish rinse agent. Is there something I can do?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jun 20, 2011 | GE Dishwashers
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
Cloudy glasses, less than 2 years old, using the same soap , we don't know what happened?
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Jan 03, 2011 | Jenn-Air JDB1105AWS Stainless Steel...
My dishwasher leaves black specks all over the glasses inside and out. They are better if left on the bottom rack but this wastes a lot of space. Dishes placed on the top rack will come out fine if the...
After you load up your dishwasher check that the top arm spins freely. Something might be stopping it. eg Big plates like I have. I can only put them on the sides.
As for the white parts , hard to tell without a picture.
Apr 06, 2017 | Dishwashers
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
Oct 01, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Kenmore 15899 Built-in Dishwasher Logo
1,230 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
