Question about Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi. I am having the same problem with my dell would you be able to put guide me in right dirction.
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Posted on Oct 05, 2008
Dell 1600n. I have to reset the printer constantly.
Do a hard reset of printer to erase all memories. Then also uninstall and reinstall the driver and see what happens. Also make sure that you are using the correct driver for your OS
Sep 12, 2017 | Dell 1600n All-In-One Laser Printer
Dell 1600n whine
under the settings for the printer you will often see an option for power save mode. if enabled warm up time is significantly longer, hope that helps a bit.
Dec 21, 2009 | Dell 1600n All-In-One Laser Printer
My Dell 1600n Laser Printer gives message Open Heat Error
Just call Dell Tech support. It's in their policies that if you call them and complain about a heat issue, they'll replace the unit for safety reasons.
Cheers.
Dec 07, 2009 | Dell 1600n All-In-One Laser Printer
Hi. I've a Dell 1600n printer. There is plenty of paper in the drawer, but message says No Paper/Add Paper.
Remove the drawer then insert again.. if the same problem.. clean the sensor maybe its broken.
Jun 15, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Scanner locked
Reach in the cavity where the paper comes out. In the top left far corder you will find a blue sliding switch. Pull it forward and press cancel.
Jul 23, 2008 | Dell 1600n All-In-One Laser Printer
"Toner Low" message = no faxes :(
Need to do a hard reset. Contact Dell for instructions, but it will involve turning printer off, opening front cover, pushing buttons on front panel in certain sequence, etc. Each model differs, which is why you should call Dell.
Mar 20, 2008 | Dell 1600n All-In-One Laser Printer
"Warming up Please wait" error
Suspect the toner heating element (fuser) may be malfunctioning. Dell may be able to walk you through a "hard reset" that involves opening the front door, turning on an off the printer with certain buttons held down, etc.
Jan 14, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
209 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
