Question about Dryers
Dryer wont start
Dryer will not turn on when timer pushed to start just clicks power is good
  • giantsox Dec 06, 2008
    I have a different Dryer, but it is also a whirlpool (LEC8858EQ0). It worked fine yesterday morning, then last night I hit the start button, and nothing. The light on the inside goes off when I shut the door though. Does that mean it isnt the door switch?
    Scholar:
  • 83 Answers
What clicks?
The timer or a part from inside?
I am thinking either the timer control or door swith has become faulty.
Am I correct in saying that the motor does not start and/or the drum does not spin?
Posted on Sep 16, 2008
Why doesn't it start?
other than the timer noise, do you hear anything else?
is motor turning but a broken belt possibly?
Nov 24, 2015 | Kenmore Dryers
Dryer will not turn on when you push start button. power supply is good so is door working properly ....you can hear the timer running and the door clicks when opened and closed.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 29, 2010 | Dryers
Dryer does not turn on? voltage good to dryer,push
here are some other problems/causes as to why a dryer won't start, Tim :
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 21, 2010 | Kenmore 64902 Electric Dryer
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Wont start
Is the motor running but the tub not spinning? You can tell by feeling for air movement out the exhaust after you start it or by listening to the dryer (put your ear against it and listen for a humming sound).
If motor is running your belt is broken and will have to be replaced.
Sep 02, 2009 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Whirlpool LER8648LW0 wont start when you push the button
check your door switch to make sure it is good / if switch is bad it will do that / larryyb
Nov 30, 2008 | Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
169 people viewed this question
Top Dryers Experts
