Garden Logo
Posted on Sep 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Staples are loaded and won't shoot - Garden
Ron
Level 2:
Sergeant:
  • Expert 195 Answers
  • Posted on Sep 17, 2011
Ron
Expert
Level 2:
Sergeant:
Answers
195
Questions
0
Helped
74475
Points
556
Check for a jammed staple near the end. This often happens and prevents the staple from feeding all the way
My gun will not shoot staples
The most common cause of the gun not firing is loading it with the wrong staples. Look at the packaging for the staples and see if it lists the gun. Staples are NOT universal and are make for specific staple guns.
It "sounds like" it is jammed. You may have to pull out the staple with needle nosed pliers. e`1
How to Load Staple Gun
How to Troubleshoot Staple Gun Hunker
1helpful
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
3helpful
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
How do you load staples in ET501? I pinch the back of the loader together but it won't pull out.
Try pinching it and pushing it down at the same time. If that doesn't work then there is likely a jam.
What part do I need to remove to make a bostich MIIIFS floor stapler to shoot 2 inch staples
You shouldn't have to do anything to the MIIIFS flooring stapler to shoot 2" staples. It is designed to shoot 1 1/2" to 2" staples right out of the box. If your stapler won't feed 2" staples, check the magazine all the way up to the power head for any foreign material that may hold up your staples.
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
Top Garden Experts
Jay Finke
Jay Finke
john h
