Everytime i try to print it says that the print spooler isnt working. can you help?
  • carmelslokum Sep 16, 2008
    it now says i need to install a printer. can you still help?
You need to start the Print spooler service, this is in the control panel, under administrative tools, under services - then find print spooler and either start it or restart it.
Robin
Posted on Sep 16, 2008
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
I have a lexmark x3400 printer and a windows 7 operating system. The current print job won't cancel and won't delete and I can't print anything else. I can't uninstall the device as it says the printer...
You will need to clear the print queue first before trying to send another print job. - Browse to Start -> cmd... and type in "NET STOP SPOOLER (this will stop the print spooler service) - Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> type cmd... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 24, 2011 | Lexmark X3470 All-In-One InkJet Printer
Wont print. saya the spooler isnt working
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 01, 2010 | HP Deskjet 2460 InkJet Printer
Compaq computer running vista trying to add a printer message local print spooler is not running I have started the print spooler through admin tools but everytime I close the control panel it must switch...
Start the simple route: uninstall and reinstall the printer and its software. If the software is old, head to the printer manufacturer's website and download the latest driver package.
Meanwhile, track back to when the print spooler worked successfully. Was there any new software installed that may have caused the problem? A possible update from Windows, perhaps?
Sep 24, 2009 | HP Compaq Presario C500t Notebook
Print Spooler Problem
In Printer Properties choose PRINT DIRECTLY TO PRINTER
Feb 03, 2009 | Brother Multi-Function Center MFC-240C...
Print spooler
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
To restart the spooler :-
click start --> run
type net spooler start click ok
or
click start --> run --> services.msc --> click ok
scroll down to print spooler --> right click on it and select start
Jan 30, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Printer
try to check the print spooler, maybe its not started..
go to control panel and open administrative tools. open services and look for print spooler. start it if it is stop or restart it if it has been started
Feb 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
41 people viewed this question
k24674
jasbo
jasbo
