Question about Panasonic Videoprojector PT-LM1E Multimedia Projector
Lamp replacement After replacing with a new lamp, the projector lamp warning light flashes and there is no projection to enable me to go into menu and re set. Is there a reset button on the projector itself ?
  • 2 more comments
  • cyoung966 Sep 26, 2008
    Thanks, the projector is a panasonic PT-LM 1E
    If you know the procedure I'd be very grateful!
  • kapokkie Oct 08, 2008
    I REPLACED THE LAMP,BUT AFTER A WHILE THE MACHINE WARNS ME TO REPLACE THE LAMP!HOW DO I RESET THE PROJECTOR TO 00HOURS AS WELL??
  • 2great2cheap Jan 05, 2009
    how do i reset my panasonic projector pt-lm2e lamp hours? thanks
  • rikmeds Mar 30, 2009
    replaced the lamp but cannot reset hours any ideas ?
    Champion:
  • 221 Answers
If the lamp warning light is lit steadily, the lamp is at fault. if the lamp warning light is flashing, the ballast (lamp power module) is at fault
Posted on Oct 31, 2008
  • 563 Answers
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Posted on Sep 26, 2008
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
resetting procedure.
1. inset the new lamp.
2. power on the projector.
3. Press menu and select OPTION.
4. Press enter button and the select LAMP RUN TIME.
5. Press and hold MENU button for 3 seconds.
6. Lamp reset , power off message will display.
7. power off the projector. this will reset the lamp hour.
Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
ok
Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Can't get the lamp light to turn off on my sanyo xp57 projector. replaced the lamp and the lamp warning light won't shut off.
Go into the menu and look for the settings icon. Under the setting icon you should see a lamp counter reset button. Select that and the lamp replacement light will go out.
Jul 30, 2009 | Sanyo PLC-XP57L LCD Projector
Replace lamp soon flashing during warm-up
Press the left and right buttons, as well as the power button once the lamp has turned on. This will reset the lamp life counter.
Jan 16, 2009 | Mitsubishi XL5U ColorView Multimedia...
Green haze projected on wall
the Lcd panels were broken, you need a new one,USD120
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Oct 26, 2008 | Sanyo LAMP Projector Lamp FOR...
Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
989 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
