LSU error code
Hi
I have a Xerox WorkCentre PE 220 and apear LSU error code after switching cartridge . Can copier but can't print .Please help me .
    President:
  • 2,072 Answers
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Posted on Sep 17, 2008
Installed a new cartridge. I get the "LSU ERROR" when I try to copy something.If I copy with my old cartridge there are no problems.
IF the new cartridge is not manufacturer approved product it will most likely not print as the printer will be programmed to identify and reject any unapproved cartridges.
Jan 08, 2016 | Xerox WorkCentre 220 All-In-One Laser...
L.S.U. error is coming what will be the problem
hello , you have to replace your laser scanner unit. lsu unit. it is damage.
Aug 31, 2010 | Xerox WorkCentre 220 All-In-One Laser...
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
In Xerox PE 220 I could not receive my fax
YOU MUST CHANGE THE CHIP BECAUSE WHEN THE MACHINE SAYING THAT THE TONER IS EMPTY ALTHOUGH IT IS PRINTING IT DOESN'T PRINT THE FAXES
Apr 04, 2009 | Xerox WorkCentre 220 All-In-One Laser...
HI I M JIGNESh patel i was purchase xerox pe in my printer error is lsu how can i solve it pls send me reply
I'm not sure what the problem is or what machine you are using but follow the link below and enter the name of your machine and then the error message and it should help!
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_US&metrics=HDR
Dec 06, 2008 | Xerox Phaser 8500/DN Printer
LSU ERROR DISPLAYED FOR XEROX WORKCENTRE PE220
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
May 25, 2008 | Xerox Phaser 8500/DN Printer
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
405 people viewed this question
