Nu-Tec parental lock
Hi There,
I bought my Nu-Tec about 6 years ago & don't have the manual anymore. Somehow I locked the TV via the remote. My TV does not have a re-set button & I tried the menu button on remote & volume down on TV, menu button on TV & zero on remote but have had no success. Please help
Help
Posted on Oct 28, 2008
  • Benid Little
    Benid Little Nov 19, 2010
    i know with the nu-tec nue3201 it can be reset with the four digit code 8034, i had found this by accident because i locked some channels and could not remember the code so i started a painful elimination of four possible digits between 1 to 9 there is thousands of combination's so this may or may not help thats even if u have an option to enter a four digit code
Nu-Tec n126 forgot parental code
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Jun 27, 2017 | Televison & Video
Parental controle
try 0000, or 1234 is this a tv or a computer?
Thanks,
Lee
Sep 01, 2008 | RCA TruFlat 27F520T 27" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Just bought a used older model rca tv parental controls locked. any master codes to bypass parental control
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Jan 03, 2011 | RCA 27V520T 27" TV
Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital antener. all works but I can't get any channel 9 stations no matter how many times I rescan channels?
''Brought a Coles $259 Nu-tec DVD/Tv combo got it home and set it up with a indoor digital ''
Poor English!
It should read; ''Bought a Coles $259 Nu-tec DVD/Tv combo, brought it home and set it up with a indoor digital ......''
Jun 12, 2010 | Televison & Video
Forgot my password on my 27
If you forget your password, simultaneously press and hold MENU on the
television and volume down on the remote for 3 seconds. Nothing appears on the screen, Parental Controls simply unlock and you can re-enter a password via Lock Parental Controls. -(F27442 User Manual pg.38)
Mar 13, 2010 | RCA F27442 27" TV
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
Apr 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Nu tec crt 54cm tv
the problem is the volume/sound
Oct 28, 2008 | Televison & Video
Nu-tec NTV2131 51cm TV
Press the 'display' button for 5 seconds
Mar 31, 2008 | Hotpoint RVM1625 Microwave Oven
Parental controls
MENU button on the television simultaneously for 3 seconds. Parental
Parental Controls
Aug 26, 2007 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
308 people viewed this question
Top Televison & Video Experts
