Question about Hotpoint Ovens
Fan rattling in Hotpoint BS41 oven
The oven is very noisy. When operated a loud rattle is coming from the top section of the oven between the oven and hob. It sounds like a fan rubbing on something. After the oven has been on for >30 minutes the noise sometimes stops. When this happens it sounds like a fa is slowing down to a stop.
Is there a fan in there that can be replaced?
    Sergeant:
    Champion:
  • 200 Answers
Posted on Sep 16, 2008
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
How to repair exhaust fan rattle?
You can look at fan closely and see if there is a set screw holding the fan to the shaft. It could be loose causing the rattle. If that is not the problem then see if the shaft has a lot of play in it. It could be worn out and allowing the fan to rattle. If that is the case then replace the fan
Apr 26, 2014 | Bosch HBL 642AUC Electric Single Oven
My oven has a rattling sound coming from a fan situated above the grill but you can't see it.
The fan you refer to is the external cooling fan, if the oven is built ijn, you will have to remove it from the housing to access the fan, and then remove the top cover of cabinet and possibly the rear cover as well.
Dec 11, 2010 | Zanussi ZDQ695 Electric Double Oven
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
Loud fan rattling in convection mode
On the repairs I have done, it has always been a bad fan motor bearing. The only way you are going to be able to tell is to tear it down to the fan assembly and feel if the fan blade or blower is loose. Good Luck, Appliance Specialists
Jan 17, 2010 | Ovens
Fan rattles no does not heat
If the fan is working, but there is no heat in the oven at all, then it is going to be the element that is faulty, assuming it is an electric oven.
If the fan is rattling, then could be loose fan blade, or the bearings are failing.
Hope this helps.
Dec 14, 2009 | Smeg Ovens
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 21, 2008 | Ovens
Ovens Logo
1,064 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
