Centrex washing machine ctw60519
Can anyone tell me how to remove the agitator as there is something caught under neath it
sandy
  • Billys Mum Oct 17, 2008
    We have the same problem with the Centrex ctw60519 6k washing machine.
    We need to get the agitator out to remove something that is caught & making a scraping noise.
    Thanks
    A.P.
The agitator is only stiff. Do not lift from one side only.
Loosen the centre with some CRC, spin by hand a few times. Then place a hooked pice of strong wire under tow opposite edges and lift.
Posted on Sep 04, 2009
How to get things caught under agitator
Remove agitator. Model # needed to tell you how.
Sep 12, 2017 | Washing Machines
Seems like something is caught in the machine and stops the spin
when spinning the agitator and bowl spin as one unit
check for proper operation under machine
call a technician for a proper diagnosis and quote
Aug 18, 2016 | Washing Machines
Clothing gets caught under the agitator wings like sleeves on shirts, strings on clothing ie hooded sweatshirts.
This is something that happens with most top-load washing machines. As long as the agitator has wings, stuff will get under them. That is one reason that front-load machines are becoming more popular.
May 10, 2015 | Crosley Washing Machines
Remove towel from under agitator
work agitator back and forth while pulling n towel is all I can tell you .
Mar 05, 2015 | Whirlpool 3.6 cu. ft. Traditional Top Load...
How do I remove clothes from under agitator?
Believe it or not the agitator will come off. Look under the fabric softener cup. There should be a fastener (nut or bolt) to loosten. Give the cup a good cleaning while you have it off.
Once the nut is removed you can work the agitator off.
Jul 27, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
I have whirlpool model LSR7233EQO and one belt of cotton stuck under the propeller
If you are referring to something being caught under the agitator, you can remove the agitator easily, by following these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
With the agitator removed, you can easily retrieve anything caught underneath. When reinstalling the agitator DO NOT overtigthen the center post nut. Tighten until snug.
If this is not what you are referring to, please post back and let me know, so I can provide you with better assistance. I hope this is helpful to you.
Feb 28, 2010 | Washing Machines
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Centrex top loader washing machine Model # CTW60519 6kg Auto Washer. When washing the center screw holding the base plate unscrews. The base plate lifts and the clothes are not washing clean. We have...
The part that the screw holds is turning independently of the screw. Remove it and inspect for torn splines or other motion locking device. Repair or replace the part using Loctite on the screw threads.
Sep 14, 2009 | Washing Machines
Makes a grinding noise when on wash
HOW OLD IS THE UNIT ? IT COULD BE THE TRANSMISSION BEARINGS. IF UNIT IS MORE THAN 5YRS BUY A NEW MODEL
Aug 19, 2009 | Washing Machines
Towel caught under agitator
remove the top part of the agitator and inside youll see a nut that will have to be taken loose so tht you can get the agitator to raise up high enough to get the towel out
Feb 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
511 people viewed this question
Top Washing Machines Experts
