Question about Xerox Phaser 8550DX Laser Printer
Xerox phaser 8550 printer
I can't find the serial number anywhere on the printer, is ther any other way I can get the serial number? On my old 8550 it was kept in a pocket on the side of the printer
  • 2,072 Answers
You can print out a configuration page, It will contain the serial number.
Posted on Sep 17, 2008
  • Rick Kasper Sep 17, 2008
    It may be on the startup page also. But I do know a configutation page will have that .
Where is serial number on old singer sewing machine
The serial number could be located anywhere. Usually it is stamped into the metal--look at the back of the machine or even underneath. Note--older Singers do not have model numbers, only serial numbers.
This may help you learn more about your machine when you do locate the serial number:
Singer Sewing Machine Company Serial Numbers
Jan 01, 2016 | Singer Sewing Machines
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Hi I need to get the ip address from a xerox phaser 8550. unfortunately i cannot read the control panel display. Is there a way to get the ip address without being able to use the control panel?
Your printer needs to have the default menu item selected. It would be "Walk-Up Features". Restarting the printer and waiting for it to be ready would be the best way to be there, but you should be able to hit the back button a few times and up a few times to get to the first menu item.
Anyway, from the default menu item, press down once (highlights Information). Then OK (enters Information menu). Then down twice (highlights Information Pages). Then OK (enters Information Pages). Then OK again to print the Configuration Page.
Also, if your printer has never had its control panel display replaced, you can get a free one from Xerox, even out of warranty. Just call 877-571-7765 with the serial number of your printer.
Jun 28, 2010 | Xerox Phaser 8550/DT Thermal Printer
I want to install Lemark printer at my pc so i dnt have its serial numbers
You don't really need ther serial numbers to install. They are primarily for registering the printer with the manufacturer. If you want to do this, the seial number is usuallly located on the back of the printer.
Mar 19, 2010 | Office Equipment & Supplies
Where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
Mar 08, 2009 | Canon PIXMA MX310 All-In-One Printer
I have alot of 8550 ink left over from my old printer.
Same ink but, it may be hard to cut them correctly to hit the switch on the bottom of the ink loader. They will code out with 09,xxx,xxx codes if they don't move down the loader properly.
The shape is the difference in those sticks.
Jan 12, 2009 | Xerox Phaser 8560DN Laser Printer
I can check if I find the service manual.
Oct 28, 2008 | Xerox Phaser 8550/DT Thermal Printer
Phaser 8550 Panel
It comes with directions. It is real easy to replace. Just call 10800-835-6100 and have your serial number ready. They will ship it out.
Should take 5 minutes to replace. Yeah a computer tech is quite able.
Aug 22, 2008 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 - no lcd display. tried switching off and unplugging and restrating. No success.
I called and they are sending me a new one. The number I found for this is 877-571-7765 - You will need your serial number on the insude of the front flat - pull grey handle.
Aug 09, 2008 | Office Equipment & Supplies
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
Xerox Phaser  8550DX Laser Printer Logo
114 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
