Question about LG WFT1071TP Top Load Washer
Dead LG WF-T8016TP washing machine
My LG WF-T8016TP washing machine will not turn on. No lights on the control panel. HELP
  • 3 more comments
  • cleaning101 Sep 16, 2008
    Sorry I should have said that I check all that. The washer is the only appliance on that power point and the fuse has not blown, I checked that as well. Thanks
  • vp_Louie Oct 05, 2008
    My Top Loader LG Model WF-T1032TP
    washing machine will not turn on. No lights on the control panel. There is power to the wall plug. Is there an internal fuse? (The power-in goes directly to the on/off button.) Everything stopped during the wash cycle and remains dead.
    Louie
    vp_louie@yahoo.ca
    washing machine will not turn on. No lights on the control panel. There is power to the wall plug. Is there an internal fuse? (The power-in goes directly to the on/off button with no apparent fuse.)
  • sanjaynand23 Oct 26, 2008
    I HAVE MASHING MACHINE WF-S6607TC IT FILL THE WATER BUT THE ON THE CONTROL PANEALS BLINKS WASH AND SPIN AND STOPS
  • carboy88 Feb 08, 2009
    I have the exact same washer (LG WF-T8016TP) - what was the solution to this problem? I could not find an internal fuse anywhere - took off the control panel and looked behind it. The washer just died in the middle of a wash cycle.
    Any ideas before I resort to a service call?
    thanks
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
Solution # 2 worked for me. I used a 15A "fuses for microwave ovens".
item bar code 0 68938 90277 3. Cost $ 3.00
Thanks
Posted on Apr 26, 2009
    Scholar:
  • 83 Answers
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
  • Richard Florey Sep 20, 2008
    If you are capable, without going to the extent of replacing the electronics card behind the control panel, are you able to to trace the mains (power) cable through to the card to see if there is an onboard fuse to check its condition?
Dear expert of LG WF-F783PC (washing machine). i am using an LG washing machine model LG WF-F783PC.its giving a warning alarm after 3-5 seconds of operation (wash & spin mode)
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve.
It is best to remove them , check reset after cleaning.
Nov 02, 2011 | LG WFT1071TP Top Load Washer
My model is WF T8016TP I am having the PE Error when i start the washer
-Unplug the machine
-Remove the pressure sensor, a 3 inche round piece under the back of the top-cover.
-Clean it, by pushing whater in the small hold. (I used what we could find a the drugstore for ears cleaning.)
-Start the machine Without putting them back and wait for the error message. (like we do for PC hardware)
-Replace the sensor, start your machine and the error message should be gone.
Hope it works.
Jan 31, 2011 | LG Washing Machines
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Users manual
The LG Canada website has it.
http://ca.lgservice.com/index_b2c.jsp
Click on "Owner's Manuals" on the left hand menu and fill in the details, model number WF-T8016TP. You'll need IE, not Firefox...
Jan 24, 2009 | LG WFT1071TP Top Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Dec 19, 2006 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
1,882 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
