CONVERGANCE ISSUES LOOKS LIKE 3D, COLORS ALL SEPARATED, WHAT DO I NEED TO GET, AND HOW DO I CHANGE IT? THANKS
  • 8,617 Answers
You will need to replace the convergence ICs. Please respond to this same post with the model number of your set and I will be able to assist you further.
Posted on Sep 16, 2008
Triple image color separation
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 06, 2011 | Sony KP-53HS30 53" Rear Projection...
Image curves outward toward corners of screen and convergence of colors separates as you get farther from center
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2011 | Sony KP-53XBR45 53" Rear Projection...
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
The color is separating
Tv have a problems known as a convergence problems,it dead.The colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergence board must have these parts replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 06, 2011 | Sony KP-51WS510 51" Rear Projection...
Colors are separated on the display. Each color is shifted to the right from the preceeding color. Looks like a bad 3d pic w/o the glasses
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 14, 2010 | Sony Grand WEGA KDP-65WS550 65" Rear...
Looks like its n 3d mode colored shadows????
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs tobe replaced. It’s not a difficult job if you want to do this yourself, youshould require some basic knowledge about soldering-resoldering components. Tostart with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check theresistors as if they are short the ICs might blow again after sometime. Please check this picture:
There are repair kits available whichincludes repair instructions with the parts, if you want to do it yourself, youcan buy and repair it yourself. Please do rate thesolution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 09, 2010 | RCA HD52W56 52" Rear Projection HDTV
TV looks like it is in 3D
You have a convergence problem. Please see a tech about reworking the convergence board or better still, have them install a refurbished board. The refurbished board will usually have a six month warranty! Thanks for asking ,and fear no TV tech, as you are armed to get a straight answer.
Jun 30, 2010 | RCA P52929 52" Rear Projection Television
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Picture looks 3d
It is hard to see, but it looks like your red color has shifted to the right. In most projection sets there are 2 large convergence IC's which put the 3 colors exactly where they are supposed to be on the screen. When one color is way off, giving the 3D effect, and you are unable to line the colors up using the convergence menu, it means that one of the convergence IC's has burned out. This is one of the most common failures in standard projection sets. The burned out IC should be replaced and the convergence circuits realigned by a qualified tech familiar with projection sets.
Aug 20, 2007 | Sony KP-43T70 43" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Open Questions:
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
