Question about SAMTRON 55V 15" CRT Monitor
Sync out of range
My Computer Display Indicating " Sync Out of Range " how to solve the problem please reply
    Scholar:
  • 147 Answers
If using windows, boot to safe mode, and make sure your resolution is low enough for your monitor to handle.
Check your cables to make sure there are no broken pins.
Posted on Sep 16, 2008
Sync:out of range
Can you give any more details? Does anything else come on screen before that message?
Try this site which deals with the problem.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&docname=c00061509
Mar 27, 2014 | Compaq Computers & Internet
Sync is out of range on rbg
I THINK YOU MEAN (RGB) PLEASE EXPLAIN SYNC IS OUT OF RANGE DONT UNDERSTAND?
Apr 16, 2013 | InFocus Proxima UltraLight X350 Multimedia...
My samsung 750s monitor has a message saying sync. out of range
When you turn off the pc the monitor loses the sync signal and should go into a suspend mode where the screen is blanked. The power management settings should be checked. In display properties check that the monitor is installed correctly.
Jun 06, 2010 | Samsung SyncMaster 750S Monitor
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Sync out of range
start the pc and get Sync out of range problem...i changed resolution but still the same..I have Samsung 753s and radeon 9800
Jul 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Sync out Of range
You need to get the monitor back into a range it can use and the best way is to go into SAFE mode on the pc put it back into 640X 480 and at 60 hz refresh rate. 37.9khz is way too high for the monitor!
It is best in the 60hz to 80 hz (if it can go that high!) start at 60 to begin with and it will work.
Good Luck!
Rich Lilja
Nov 24, 2008 | Samtron MONO TTL 13 Monitor
Display sync out of range
start the computer in safe mode.
go to control panel>>display>>settings>>advance.
reset the screen refresh rate back to 60Hz under the monitor tab.
Nov 17, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
SAMTRON 55V 15" CRT Monitor Logo
112 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
