Question about Dyson Flowcheck CRO1 Front Load Washer
Fault F11 Hiya, we had a power cut and now the machine stops after a couple of minutes into its cycle displaying Fault F11. The Dyson engineer can't come out for 2 weeks - is this something that I can fix? Thanks
    Problem Solver:
  • 5 Answers
Yes. Needs at least a fuse and possibly a 'bridge rectifier' fitting to the powerboard located to the right of the drum at the bottom looking from the rear with the access panel removed.
The bridge rectifier is soldered to the board but if you can drive a soldering iron its simple enough.
Posted on Jun 13, 2011
No.needs engineer
Posted on Sep 26, 2008
I HAVE FAULT F11 HOW DO I FIX IT
Dyson Memory CRO1 Front... Fault f11 Solutions - Fixya
www.fixya.com > ... > Dyson > Dyson Memory CRO1 Front Load Washer
Dyson Memory CRO1 Front Load Washer, fault f11 related issues. Get free help, solutions & advice from top Dyson experts.
Aug 08, 2015 | Dyson Flowcheck CRO1 Front Load Washer
Dyson CRO1 F11 Fault
normally error like this disappear when a hard reset is performed? did you leave the unit turned off by plugging out from wall power for one night ??
until what cycle does this unit proceed?
Jul 26, 2008 | Dyson Flowcheck CRO1 Front Load Washer
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
F15 I KNOW WHEN FIRST SWITCH IT ON THERE IS A COUPLE OF BUTTONS TO PRESS TO OVER RIDE IT JUST CANNOT REMEMBER WHICH BUTTONS DO U KNOW?
to clear fault f15 turn off the machine hold down the temperature button turn on the power release the temp button then in less than about three seconds press the soil button.a diagnostic screen will come up on the display it will display a set of numbers these indicate the number of wash cycles and the most recent fault codes followed by the software version of the computer once you have this displayed turn off the power then turn it on again the fault should have cleared if the fault code reappears you will need to contact Dyson to repair your machine
Aug 15, 2010 | Dyson Flowcheck CRO1 Front Load Washer
How do i repair a f11 code on my dyson cro1 contrarotor
Get Dyson out, the powerboard has failed, don't be fooled into thinking replacing the fuse on the board will do the job, it doesn't, a component has failed on the PCB which has caused the fuse to blow in the first place, £95 call out i'm afraid.
Dec 30, 2009 | Dyson Flowcheck CRO1 Front Load Washer
F11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
I am sure it would help you to resolve the issue.
God Bless.
Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
To Clear F11 Code after a power cut.
3, Power on
Thanks for using Fixya.
May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
3, Power on
Oct 22, 2008 | Dyson Flowcheck CRO1 Front Load Washer
DYSON washine machine fault
3, Power on
Sep 05, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Dyson Flowcheck CRO1 Front Load Washer Logo
458 people viewed this question
Top Dyson Washing Machines Experts
Starnley Johnwells
Starnley Johnwells
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
