Question about Video Game Consoles & Games
I cant get my bluetooth head set to work on ps3 i dont know how to put the blue tooth into pairing mode i dont have instructions for the bluetooth. it is a ps3 bluetooth bought from argos
Hi, i had this same problem. really annoyin. first make sure you charge the headset fully. then while keeping the slidy mouth piece closed hold down the centre button untill the blue light comes on and will start flashing. your ps3 will then be able to find it. the defualt pass code is 0000
Posted on Dec 29, 2008
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Samsung WEP460 Bluetooth Headset
PS3 bluetooth headset won't work
ive had the exact same problem
make sure that the blue tooth is in "pairing mode" when the system is scanning.
reference to the bluetooth manual to put the device in pairing mode.
I hope i have helped and I hope it works
Jan 14, 2010 | Sony Playstation 3 (PS3) Console
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I got a new ps3 and cant get my bluetooth head set to work
usually all blue tooth head sets have pass codes on them and they are very simple and in the instruction manual but i bet it is probably 0000 because that is practically the universal code for the headsets hope this helps
Feb 27, 2009 | Project Delta
Pairing mode for headset with PS3
On your PS3 XMB menu. Go to settings. Scroll down to accesories. Then click on manage bluetooth devices. There you will find the autodetect for the bluetooth headset. While the bluetooth headset is off, press and hold th on button until the LED stays on. The quickly use the PS3 to detect the blue tooth. It will ask for a pin to pair the units up. The pin is four zero's.
Jan 09, 2009 | Ubi Soft Entertainment Tom Clancy''s...
Headset wont pair with new ps3
is this bluetooth
if it is blue tooth you have to hold blue tooth power on while the pairing mode is searching for headset
if its a cabled headset threw usb you gotta put in your disk for say example= logitech since these are common
the playstation has memmory card that stores the settings but requires you at least set up usb head set parameters either to ps3 or your memmory cards properties
your headset is fine you just require a new hardware setting with the disk that came with your head set
May 28, 2008 | Sony Playstation 3 (PS3) Console
The name of your bluetooth headset is the OmniTech (OT-020C).
This will be slightly difficult to explain without knowing the model of phone... First off, you need to ensure that you are using a bluetooth enabled phone. You will need to enter the settings and tools menu. From within that menu, you need to find either "connections" or "bluetooth" and select. Make sure bluetooth is enabled. There will be an option to add a new device.
On your bluetooth headset, hold down the power button down until the power light stays lit. This may take 5 seconds or more. Now your bluetooth is in pairing mode.
Back to the phone, you want to hit "add new device". On certain models of phone you additionally have to select "search for devices". Your phone will recognize any headsets in pairing mode. When it is finished scanning, allow the phone to add your headset. It will ask you for the device pin code. This pin code will be 0000.
I hope this answered all of your concerns. If you are having trouble with finding the correct settings from within your phone, reply with your phone model and I can give you more detailed information!
Jan 20, 2008 | Motorola Mobility RAZR V3
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Video Game Consoles & Games Logo
109 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
