Question about Belkin Computers & Internet
Can not install bluetooth start belkin get this message THIS INSTALLER BE RUN ON WINDOWS VISTA ONLY
  • 477 Answers
You have wrong driver for your bluetooth, plz input your model of your bluetooth here and i will find the driver for you.
Posted on Sep 16, 2008
Will not install
what are you trying to install, when did this start to haooen?
What OS are you using (Windows version)?
Mar 26, 2013 | Belkin Easy-Transfer Cable for Windows XP...
Hello, sir/madam, i would like to know how to solve 8007007e? Thanks.
1. Run "sfc /scannow" and restart the computer;
2. Uninstall WLM9 with ZapMessenger;
http://messengergeek.spaces.live.com/blo...
http://www.softpedia.com/progDownload/Za...
3. Donwload and install Windows Installer Cleanup Utility for vista/windows 7;
Windows Installer CleanUp Utility 1.0
http://support.microsoft.com/kb/290301/e...
4. Run the utility, select all items concerning Windows Live and remove them;
5. Run WLM9 installer again.
Windows live Messenger 2009
http://download.live.com/?sku=messenger
Nov 01, 2010 | Microsoft Windows Live Messanger
Windows Vista: I cannot install anything at all.
Is your Vista a 32 bit or 64 Bit O/S
open this link and run the Windows readiness tool, This will help the PC unblock any failed updates for Windows and help you install the new updates.
http://www.microsoft.com/downloads/details.aspx?FamilyId=b4d90b06-c27d-4483-bc1f-04d43fa7b293&displaylang=en
Windows installer for Vista is Installer version 4.5, so the updates should fix the issue.
Jun 29, 2010 | Computers & Internet
When installing Java, at the end the message ''Error 1721. There is a problem with this windows Installer package''. A program required for this install to complete could not run. I've tried everything....
Try the steps laid out in this MS KB article about the installer service:
Reboot the computer, after it beeps start pushing F8. You should get a menu. Select Safe Mode and push enter.
Once Windows comes up click start and type in CMD (for Vista/7). Right-click cmd.exe and select "Run As Administrator". (For XP: click start then Run. Put in CMD and click OK).
Put in
msiexec /unregister
Then bring up the Run box again and put in
msiexec /register
Close the CMD box and reboot the PC, letting it boot as normal. Try the Java install process again. If it still doesn't work try the SFC command listed in the above KB article (which I can help with).
Jun 06, 2010 | Microsoft Windows Vista Home Premium...
When I tried to download javas new update it sent me a message saying windows installer is not opeating properly. I'm running Vista home basic. Can you help
Try to ensure that Windows Installer service is running, or force start it. 1.. Open Run, and type in services.msc then press Enter. Alternatively, go
to Control Panel -> Administrator Tools -> Services.
2.. Locate Windows Installer in the all install services listing.
3.. Verify that the Status is Started. If the Status column is blank,
right click on Windows Installer and select Start.
4.. If you get error trying to force start the Windows Installer service,
try to change the Startup Type to Automatic (default is Manual), and then
restart the computer.
I would suggest you to run SFC scan which would scan for corrupt system files on the computer and replace them.
Steps to perform SFC scan:
1. Click the Start button
2. From the Start Menu, Click All programs followed by Accessories
3. In the Accessories menu, Right Click on the Command Prompt option
4. From the drop down menu that appears, Click on the 'Run as administrator' option
5. If you have the User Account Control (UAC) enabled you will be asked for authorization prior to the command prompt opening. You may simply need to press the Continue button if you are the administrator or insert the administrator password etc.
6. In the Command Prompt window, type: sfc /scannow and then press Enter
7. A message will appear stating that 'the system scan will begin'
8. Be patient because the scan may take some time
9. If any files require replacing SFC will replace them. You may be asked to insert your Vista DVD for this process to continue
10. If everything is okay you should, after the scan, see the following message "Windows resource protection did not find any integrity violations"
11. After the scan has completed, Close the command prompt window restart the computer and check.
Nov 09, 2009 | Microsoft Windows Vista Home Basic Edition
When opening sidebar windows installer opens .
It is likely some sidebar gadget you've got installed that wants to use bluetooth.
Take a look at the installed gadgets, and see if that makes sense. To administer gadgets (I am assuming the sidebar is not opening properly), but do try to start it, then:
Start
Control Panel
Windows Sidebar Properties
View list of running Gadgets
Remove any gadgets that may cause the trouble.
Feb 09, 2009 | Microsoft Windows Vista Ultimate Edition
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Installing belkin bluetooth device
You can install software for XP ( eventhough you are using Vista).
I have installed it and it worked. :D Good Luck
Jun 29, 2008 | Computers & Internet
Belkin F5D7132: cannot open exe program
Windows Vista; belkin says it's compatible. install program downloads, but desktop shortcut does not appear. When I attempt to open the file, I get error message "IP802MR MFC application has stopped working." IP802MR is the name of that file.
Jun 17, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Computers & Internet Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
