Question about Canon Office Equipment & Supplies
Canon 3080CII vertical tramlines on bottom scanner. I have removed the lens glass and thoroughly cleaned it and the area to no avail.
You need to go farther than the lens glass. The dust is actually on the photo board itself. I'm assuming that the problem is on the bottom scanning side. You will need to dis assemble the scanner to remove the scanning unit. This can be done by remove the back, the sides, and the two front pieces. Once inside remove the silver metal cover over the rollers. This will help you get the actually scanning equipment out. Remove the black scanning unit behind the silver metal cover.
Make sure to ground yourself before continuing or you could short the boards.
Under the lens glass there are three boards. Two are visible. One is white, long and skinny. On the backside one is green. The one you need to get to is hidden between the black piece, and silver metal piece. There should be 6 screws that you will need to remove first.
Very gently pry the plastic from the metal. The problem that you are looking for is there.
Wipe the photo cells with an alcohol swab, and you should be good to go.
Posted on Apr 02, 2009
I've cleaned the glass and still have a black line on the image
Scan a document in 300 dpi in full width. Check where the line appears in the image. For example if the black line appears at vertical position say 1900, then it means the dirt is at 1900/300 i.e., 6.3 inches from left. Clean the area thoroughly. Check if any pin had created a scratch in the glass. At different contrast levels, if the line appears different, it is definitely unclean glass. On the contrary, if the line appears constant at various levels of contrast, then it is possible that scan module is faulty.
S. Mohan, India
Aug 04, 2011 | Canon DR 2080C Path-Through Scanner
Light lines in back ground on scanned pages
Please clean the glass thoroughly with a damp but well wrung cloth. No solvents please!
S. Mohan
Jan 23, 2011 | Canon DR-3080CII Path-Through Flatbed...
Black line the length of page
Please clean the glass surface throughly with a damp cloth.
S. Mohan
Aug 26, 2010 | Canon DR-3080CII Path-Through Flatbed...
I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Jul 14, 2009 | Canon DR-9080C Path-Through Scanner
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Jul 10, 2009 | Canon DR 3080C Path-Through Scanner
How do I clean the rollers on a canon DR-3080CII The paper seems to be slipping a little.
Lightly dampen a cloth with water or rubbing alcohol. Gently rub across the roller side-to-side, rotate a little, and continue until you've gone all the way around. The most important rollers are the 3 at the paper feeding area  (2 top & 1 bottom). The bottom roller will be harder to turn than the top 2. Just be gentle & patient to avoid tearing the rubber. Frequent light cleanings are better than waiting for problems to crop up.
Apr 06, 2009 | Canon DR-3080CII Path-Through Flatbed...
Canon Dr-5020 grabbing multiple pages
Wipe the rollers with a damp cloth thoroughly. Remove all the dust in the glass for a claen scan. The red color roller roller in the bottom needs thorough cleaning, rotate with hand gently (in power-off mode) and clean it thorughly. No solvents pls, except Isopropyl alcohol for cleaning
S. MOhan, Chennai, India
Mar 03, 2009 | Canon DR-5020 Path-Through Scanner
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
I have a Canon DR-3080CII scanner that is making a lot of noise.
If you haven't had problems then they are probably fine. The feed rollers are rated for 500K pages, and usually last at least half that even under severe duty.  Regular light cleanings by the operator are recommended. Once a year a service tech should do a more thorough cleaning of the transport rollers & sensors. When the rollers do wear out, you can purchase them from online retailers like ScannerSolutions.com, but they aren't designed for easy user installation. Call your local dealer for a quote; the extra expense is worth the saved effort, and they should do a complete cleaning at the same time.
Aug 19, 2008 | Canon DR-3080CII Path-Through Flatbed...
Line on Blank Pages
Oct 17, 2007 | Canon DR-3080CII Path-Through Flatbed...
172 people viewed this question
old marine
old marine
Corne Viljoen
