Question about Whirlpool Calypso GVW9959K Top Load Washer
Win vista cd key in xp professional
I purchased a new pc with both win vista and xp professinal sp2.However the xp cd does not have a key.can i use the vista key to install my xp copy.or how can i offerwrite the registration for vista into xp.
Serial key
Posted on Oct 13, 2008
Usually when you purchase a new pc with the operating system installed, they put a sticker on the machine with the CD key on it. You may have the XP key sticker on the machine. Good luck.
Posted on Sep 25, 2008
There are four lights on front of the washer we replaced the door lock and the sensing light is on. water goes into the machine but nothing else happens. we also cleaned out the pump what do you t
I appreciate your inquiry, terri buttafuoco!
Based off the information you have provided you have replaced the door lock on your Frigidaire washer and it is still not operating properly. It sounds like a possible problem with your control panel or wiring harness. I would recommend reaching out to a professional for proper diagnosis and repair to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Oct 25, 2014 | Frigidaire ATF6000ES Front Load Washer
HOW DO I TEST THE DOOR LOCK?
Hello friend, thanks for your inquiry!
I understand that you would like to test your door lock on your Frigidaire washer. I was unable to locate that information regarding testing the door lock. I would recommend performing a generic search online for further instructions on how to test the door lock or consult with a professional for proper repairs. Getting assistance from a professional can help avoid any unnecessary part purchases. Hopefully this helps. -Matt
Sep 16, 2014 | Frigidaire 131763202 Washer Door Lock
Fisher Paykel front control board power on press key not accepting. As if it is stuck?
how old is the machine? all buttons are rated for a certain number of presses. they can be removed with a soldering iron and replaced with similar buttons if you are so inclined. or a new board can be purchased from F+P.
Oct 29, 2013 | Fisher and Paykel Washing Machines
Frigidaire Affinity ATF7000 installed new door switch now says cd
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
15 yr old Roper dishwasher won't drain. I have to bail out water with small bucket. Plumber says pump must be out and better off to buy a new dishwasher. Should I get it fixed or buy a new one?
My advice is with the plumber, however the washer is doing it's job then buying a new pump is the way to go and now during these economic times if you can maintain a budget balance by repairing the device and it saving money then the repair wins every time. the washer will pay for the purchase of a new pump ( if you can find one for that model) over an over again. Then save for the new washer when this washer has seen it's usefull days.
Hope this helps. Have a great day!
Mar 10, 2010 | Roper RAS6233KQ Top Load Washer
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I think the technician installed a bootleg copy of XP on my VAIO when he replaced the hard drive. What are my options?
First, what version of windows did you have before? if you had Windows XP do you still have the Certificate of Authenticity (known herein as a C.O.A.).
Some computer manufacturers put the COA on the bottom of the laptop.
Some enclose them with the manual and paper work pertaining to Windows when you bought your computer.
If so just, do a repair installation and use your COA.
I am suspect of any Tech who uses a hacked Windows OS.
If you cannot find the COA that came with your computer, then your options are as follows:
Buy a new copy of Windows XP cost @ $100 - $150
of Vista or Windows 7.
use Ubuntu Linux desktop cost - Free
easy to use and little to no worries about hackers, viruses and having to install drivers.
Nov 30, 2009 | Washing Machines
Roper coin operated washer and dryer with no keys
call A locksmith to drill out the lock then re-key the machines
Dec 19, 2008 | Roper RAK2751WWH Top Load Washer
Washer won't agitate or spin
what you need is a motor coupling. it connects to the motor and the other end of connects to the transmission. the part about 10.00 but i recomend having a professional install it because it can be tricky. i suggest you buy the part at a parts store or even online to get it even cheaper and then have someone install.
Jan 23, 2007 | Roper RAB2121KW Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
449 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
