Question about LG RZ-37LZ30 37 in. LCD Television
TV CONNECTIONS I have LG TV 37 LC2R and I wish to connect 1. Cable line TV 2. DVD Video Recorder 3. VCR / DVD Player Can you help me please
  • 1 more comment
  • caromio68 Sep 16, 2008
    My problem is that I have lost the Manuals of both the DVD Video Recorder and the VCR Player. I have a splitter but I don't how to connect the TV + RECORDER + VCR PAYER .
    Please can you help me.
    Thanking you
    Thank you for your reply .Sorry to ask you another question. My connection wires are the scart types on each end.Can you help me please.
    SOME HOW I AM HAPPY
  • 4,472 Answers
You want the video and audio outputs from all your players and cable box. to the video/audio INPUTS on your tv. It is that simple. If you still have any questions please let me know. If you have a moment to accept and rate this solution I would greatly appreciate it.
Thanks,
Lee
Posted on Sep 16, 2008
    Master:
  • 763 Answers
If your cables are not compatible or incorrect ends then try to buy an adaptor to fit to the right connectors. so you will be able to connect each ends.
CHARCOIS
    Genius:
  • 1,269 Answers
You can download the User Manual HERE
    Master:
  • 726 Answers
Ok tv from out put the 3 rca yellow red white into recorder input yellow video red white audio
the from recorder split to vcr
    Guru:
  • 1,894 Answers
  • dewan nafees ahmed Sep 16, 2008
    this was the source
    http://forum.donanimhaber.com/m_9875434/...
  • 435 Answers
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Dstv to dvd recorder connection
  1. Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
  2. Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
  3. With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.).
Mar 11, 2009 | LG DR787T DVD Recorder
How to hook up vcr and dvd together ?
|DVD| -> |VCR| -> |TV|
1. Connect your VCR to your TV. (Using Antena cable or RCA cables.)
2. From your DVD player, choose the AUDIO VIDEO OUT. Then, connect that to your VCR's LINE IN jacks.
(*)Your DVD player has 3 jacks coming out. Yellow-video, White- Audio Left and Red- Audio Right.
If you VCR does not have the RED jack. Go to a radio shack and tell on of the sales person taht you need to connect 2 RCA audio outs to 1 RCA audio in. (He/ She will give you a "2RCA Male to 1RCA Female" splitter)
3. Finally, play your DVD, put your VCR channel in TV and most important select the LINE channel in your VCR. (This channal may called as L1, Line,... etc)
You should be seeing the DVD in your TV now.
If you want to play the VCR, just put the casset and play.
Important- The VCR needs to be powered on in order to the DVD signals to go to the TV.
Cheers!!!!
Feb 27, 2009 | TruTech TT1620 DVD Recorder
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
LG RZ-37LZ30 37 in. LCD Television Logo
179 people viewed this question
Computer Repairing
Computer Repairing
