I am having creative zen 4gb MP3 player, its screen doesn't appear at all. its just one month old
SOURCE: Zen Micro
Sounds like it may be the index in your Music Library. Try going into Recovery Mode; remove battery, hold power switch to ON, replace battery, release power switch when the Recovery Mode screen appears on the screen. Run Option 1 CleanUP, after it completes run Option 4 Restart. You will get a Rebuilding Library screen when it reboots, that's normal, then it should go back to your startup screen. Good luck and let us know what happened
SOURCE: user manual for Creative Zen V Plus 4GB Digital Multimedia mp3
You will need Adobe Reader (free) to read the manuals
If needed use the following link and click "Get Adobe Reader"
http://www.adobe.com
link to manuals
http://us.creative.com/support/downloads/download.asp
Click on manual and follow instructions to download.
SOURCE: creative zen touch mp3 player
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch. if that doesnt work try this:
I decided to open it up to check out the hard drive to see what
kind I would need so I could try replacing it. The data plug that
attaches to the hard drive itself was partially unplugged. So, I pushed
it back in all the way, put it all back together again, and turned it
on just to see if something different might happen. (I had it set in my
mind that the hard drive failed and I would need a new one, so I didn't
expect anything different to happen) And to my surprise, it worked just
like new again
when you get it working
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
SOURCE: My Creative Zen 4GB MP3 Player is just not turning On
i would recomend you to first press the reset button then conect it to your computer again using the correct usb port. then you have to restart your player so your computer recognises it!! good luck
SOURCE: my creative zen mp3 wont load
try conecting it to the computer and reinstalling the firmware to it that helps sometimes
