Question about HP OfficeJet d145 InkJet Printer
Hpofficet d145 Scanner failure. I cannot take a copy or receive a fax. Are the lamp defective. and how to change it.
  • 2 more comments
  • Anonymous Mar 28, 2009
    scanner failure error can't make copies. can't fax or receive even when the printer was new only able to fax maybe 3 times,
  • dlhz Mar 28, 2009
    scanner failure; unable to print or copy items; What needs to be done to correct the problems?
  • Anonymous May 01, 2009
    I have cleaned the mirrors and the lens. No way. The lamps are not defective. Parts are not available. It seems to be a firmware-problem. Does HP just want to sell new machines? I won't buy there with this experience.
  • Anonymous May 22, 2009
    The Scanner Failure light keeps coming on. I reset and it will come back on after a few minutes. I am able to print however. Can scan and copy a document after I reset until the Scanner Failure ligtht starts to blink..
    Right now I just let it blink and only use the printer function.
SOURCE: scanner failure
It's a pretty common problem for this model printer. clean the flatbed glass inside will help and if possible clean the mirrors on the scanning head will completely solve the problem. Just remind, don't use any solution. And there is a very small chance is the granding wire connector loose. Good luck.
Posted on May 12, 2007
  • 317 Answers
SOURCE: officejet 7310 HP
Follow the steps below to perform a fax diagnostics test. 1. Set up the all-in-one for faxing according to the setup instructions found in the product's User's Guide. 2. Make sure you have inserted the print cartridges and loaded paper before starting the test. 3. Press Setup, 6, and then 6. This displays the Tools menu and then select Run Fax Test. The HP all-in-one displays the status of the test on the color graphics display and prints a report. 4. Review the report. * If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems. * If the test fails, review the report for more information on how to fix any problems found. 5. After you pick up the fax report from the all-in-one, press OK. Then turn the printer off, and then on again. If necessary, resolve any problems found and rerun the test. If the test passes and you are still having problems faxing, check the fax settings listed in the report to verify the settings are correct. A blank or incorrect fax setting can cause faxing problems.
Posted on Aug 07, 2007
khanmohammad
  • 188 Answers
SOURCE: HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Posted on Mar 25, 2008
adonscott
  • 106 Answers
SOURCE: HP C6180 AIO Scanner Failure
hi,
The "Scanner Failure" usually refers to the hardware of the printer. try to do a reset.
Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
If the issue still not resolve, please call HP 1-800-474-6836. Also check the warranty status of your printer.
thank you so much.
adonscott
Posted on Jul 26, 2008
SOURCE: Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Aug 19, 2008
Copys and sent fax are showing black pages, but when receiving fax it prints out fine.
Your scanner lamp is not coming on. Could be the lamp or driver board. Either way it is cheaper to buy a new fax.
Oct 21, 2009 | Brother Office Equipment & Supplies
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
When trasmitting the receiver copy is totally dark
The exposure lamp is not coming on, try unplugging the machine for a few minutes. power it back up, Try making a copy, it uses the same parts as out going fax.
If that doesn't work, feed a page into the fax, press copy, if you look where the original comes out you should see a bright light, this illuminates the original so the scanner can see the page. If that lamp is not coming on the lamp or the control board for the lamp has likely failed.
Hope this is of some help.
Ed
Apr 26, 2009 | Office Equipment & Supplies
Hp officejet d145 carriage error & scanner failure
Re carriage error - suggest cleaning the encoder strip. this is the plastic strip running parallel to the drive belt but about 1 inch above it. They frequently become covered with ink spray and so are impossble to read by the carriage position detector.
Beware.
Only use cold water and be very gentle. also make sure you dry the strip thoroughly before switching the machine back on.
Re scanner problem 2 possibilities.
(1) make sure printer power cable is connected directly into wall socket not through an extension cable. This can reduce the voltage getting through to the scanner lamp.
(2) if that don,t work then I suggest you take the scanner apart and clean the reference strip. this is a white bar on the scanner glass which tells the machine what the light level is. This can be a bit tricky so if you've never done it before consult someone who has or get back in touch with me. HP don't want you to do this but it sometimes works.
Dec 11, 2008 | HP OfficeJet d145 InkJet Printer
Black line down the side of copied paper
is this on only copy or also on received paper.if only on copy just check ur fax scanner may be it is dirty .just clean it with a soft tissue .may be some led is gone dead inside the scanner.just see whole lamp is working or not.MIAN AKHLAQ
Nov 25, 2008 | Office Equipment & Supplies
Scanner failure turn off and back on
Try uninstalling and then reinstalling your software.
May 14, 2008 | HP OfficeJet d145 InkJet Printer
Fax Problem KX-FL541
your scaner is dirty,you have maybe nsome stuck in the scanner,or correcton fluid gooes from document to scanner lamp,check is all ok ,if everythin clean,your scaner lamp has a damaged ,try to change it or call service man
Feb 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
Scanner failure
scanner failure, turn unit off and back on, does not help
Oct 01, 2007 | HP OfficeJet d145 InkJet Printer
Scanner failure
Checxk the manual for FAQ's Check makers tech help site,looks like a service job
May 10, 2007 | HP OfficeJet d145 InkJet Printer
HP OfficeJet d145 InkJet Printer Logo
61 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
