Question about Microwave Ovens
Replace the light in a sharp microwave convection oven
  • malthatcher Sep 18, 2008
    Sharp obviously did not mean the user to service thid oven. I dissassembled the oven and managed to remove the offending globe. You were correct, a halogen globe. Replacement cost is 76AUD, about 65USD on todays exchange rate. Next time I will think about buying a new microwave oven. Not much dearer. Thanks for your help.
    Mal Thatcher
  • Microwave Ovens Master
  • 8,858 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number. We may have the manual for you to download.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
Oct 07, 2009 | Sharp R-1870 Convection/Microwave Oven
Manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
Jun 13, 2009 | Sharp R-820B Convection/Microwave Oven
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
Sharp 930 AK Convection/Microwave Oven
When you close the oven door the latches operate a couple of interlock switches that control power. It may be that one of the door switches is bad or out of adjustment. It's also possible that one of the door latches is broken so it's not hitting the switch. There should be two door latches. Are they both there? This oven could be fixed by adjusting or replacing the interlock parts as needed. Because of concerns about microwave leakage from an improper door seal, you should have this oven serviced by a professional.
May 21, 2009 | Sharp R-930AK Convection/Microwave Oven
Sharp convection/microwave R8310 owners manuel
I have the manual for the R-8310 convection microwave oven by Sharp. Contact me @ mimi@CookbooksPlus.com.
Feb 23, 2009 | Sharp Microwave Ovens
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Cooking in an old convectional microwave
Regardless of the model, the basic procedure should be the same in most Sharp convection models.
You can download several recent models here:
http://www.sharpusa.com/products/TypeManuals/0,1083,5,00.html
Nov 22, 2007 | Sharp R-1850A Convection/Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
