Unable to insert ink cartriges - Office Equipment & Supplies
  • Anonymous Apr 24, 2009
    cant get the think that you store the ink into to slide across so i can put the ink into
    Sergeant:
  • 399 Answers
Just open the front door while the printer is on. the carriage will move and stand to the cartridge install position.hold the black cartridge pust it little bit towards down till it leaves the lock and then get it ouside towards ur side.fit the new cartridge in the reverse procedure.
follow the same for colour cartridge.
thanks.
Posted on Sep 16, 2008
Motherboard problem?
In general it costs more to repair a printer than to replace it. Spares are not easy to get. Sorry.
Feb 23, 2014 | HP Officejet 6310 All-In-One InkJet...
After changing the cartridge the Black in is not working
Your printer's head mainly (black holes) may be block by dry ink. Try to clean it. To clean follow these proces:
Take black ink in a plastic seringe Then unplug black cartrige. See inside into cartrige carrier. There is a black plstic stick. Try it to insert into plastic seringe (carefull). Then push ink through black stick. ( 4/5 times) . After that you will be relive from your printer problem.
Thank you.
Sep 11, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
I have inserted both my blacl & colour cartriges properly but still my printer is showing some problem with my black cartrige
When ink cartridges get low they can dry out if you do not print that frequently. So try a new cartridge. Make sure that the carriage is clean, wipe down the copper contacts on the carriage under the black cartridge with alcohol. Also ensure that the cartridges themselves are not all coated in ink.
Dec 03, 2009 | Office Equipment & Supplies
Don't acept cartrige of ink. Allthe time the
this happens when you insert fake cartridges in HP. usually i think higher products of HP dont accept fake cartridges.
Go for vivera inks. they are genuine HP inks.
or look out for pin in the cartridge area. as it may not be settled properly
Dec 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Receiving the message "Ink Catridge problem: ink cartridge appears to be missing or damaged". I've tried everything from cleaning cartridge holders to replacin cartridges. Nothing works and the printer...
The message you are getting may be due to the following reasons :
1) Cause : One or more ink cartridges missing.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place.
2) Cause : One or more of the ink cartriges are not installed or are installed incorrectly.
Solution : Remove and reinsert the ink cartriges and verify that they are fully inserted and locked in place. If the problem persists, clean the copper-colored contacts of the ink cartriges.
Nov 24, 2009 | HP Photosmart D7260 Printer
Dear sir my hp f4288 printer cartridge is not
hello sir pl how to insert and fix the cartrige in hp f 4288 printer..i cant fix the cartrige both also..
Apr 26, 2009 | HP DeskJet F4280 All In One Printer InkJet
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I...
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Dec 14, 2008 | HP DesignJet 750c plus InkJet Printer
Hello
Did you use generic ink carts? If yes and those have a scotch tape as a seal, ink has splashed and stained the led-control board.
Do use a full brother ink cart and place it into the machine. m
always make sure that the colored latches are secured (clicked into position.
Another chance is that the generic cart is a bit too small. feed some paper BENEATH the cart. Leave some more paper to be pressed by the latches.
Feb 04, 2008 | Office Equipment & Supplies
42 people viewed this question
jasbo
jasbo
