Question about Foxconn 848P7MB-S Motherboard
Front panel connections
I need information on the front panel connections for this m/b. It has looks as though it uses a single plug. Any links to manual or pictures of pin connections etc would be appreciated. Thanks
Can someone help me on how to wire fp1 on foxconn motherboard
Posted on Mar 22, 2009
    President:
  • 2,351 Answers
Hi rorydc, you can download the manual from Foxconn at this link; http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=848P7MB-S&TypeID=en-us0000001
You will need Adobe reader to view the manual. If you do not have this installed you can download it for free at this next link; http://www.adobe.com/products/reader/ Once the manual is downloaded & opened go to the top of page 19 in Adobe reader.
Here you'll see a picture of the Front Panel Connector: FP1 Also see motherboard layout page 10 in Adobe for location of FP1 listed as number 13. With the Adobe reader you can zoom in & out.
Lastly you'll need to know which wire colors are used for positive & which are negative. Most case's use the color white & black for negative. Wire colors blue, green, light green & red are commonly positive wires. As you'll see each connection uses a 2-pin 2-wire connector for the case.
This next link is the main Foxconn web site for your board. http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000173 You might want to save this link in your favorites.
If you need more help just post it here.
Good luck orydc!
Mike
Posted on Sep 16, 2008
Motherboard
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 30, 2013 | Leadtek Winfast 760m02-gx-6lrs Socket 754...
We have a DSX4F-24MBT-E01C : ADC Front Cross-Connect Chassis. I am not able to find a free manual to download, so I am searching and compiling every bit of information, plus picture that I can find. The...
http://www.ebay.com/itm/ADC-DSX4F-24MBT-E01C-DSX3-Panel-24Term-Loaded-Front-Cross-Connect-Module-DSX-4FT-/271162226378
Not a motherboard? OMG!
So what is it Samuel?
Looks like a cross connect termination panel to me, and front loading.
Like something I used back in the old Signal Corp days, or a fancier version for the old telephone operators.
A 'Patch Panel'.
My estimate would be;
Example;
You plug into IN, on the one all the way to the Left side.
This is number 1, and number 1 switch below; goes to it.
Now lets say you plug into OUT on number 10.
Click the switch below, and these two 'channels' connect.
Got something plugged into number 7 IN? Click the switch below for it, and it is in the line.
I'm wrong? Not the first time.
But as I said. Looks like a patch panel
Regards,
joecoolvette
Mar 14, 2013 | Computers & Internet
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I lost the connection's posisition of front power switch on my MS 7309, can you please send me a diagram of connections. thanks...
2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note: The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Thank you for using Fixya.
Aug 05, 2011 | Computers & Internet
My front panel audio plugs are not connected in motherboards
Use this link and scroll down to page 43 and 44.
http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
Mar 13, 2010 | Computers & Internet
How does the power switch and led plug up on a GT5428 motherboard?
This is Gateway Support, and Support Documents for the Gateway GT5428 Desktop PC,
http://support.gateway.com/s/pc/R/1009466/1009466nv.shtml
On this page left-click on Components.
Scroll down the page to the heading - Motherboards
Left-click on -
4006158R - Intel (Coryville) 945G Motherboard
Now Left-click on - Product Views
Lastly left-click on -
O - Front Panel Connector
This shows you a photo of the Front Panel header on the motherboard.
A connection on a motherboard is referred to as a Header.
The Front Panel of your computer is the plastic part where the Power On button is.
The Front Panel header on the motherboard is where the wires from the Front Panel connect to.
The above is not to offend you, or insult your intelligence. Just wanted to give you the exact names of the parts you'll be handling.
Looking at your motherboard with the Processor to the top, and the Ram slots to the right, the Front panel header is located in the very bottom right corner.
Looking at the Front Panel header on the motherboard, you will note the different colors.
There are also Pins that stick up out of the Front Panel header.
Every 2 pins is grouped into one color.
The Front Panel header is located parallel to the outside edge of the motherboard.
There are 2 rows of pins.
One row across the top of 5 pins.
One row across the bottom of 5 pins.
The pins are numbered, as well as grouped into colors.
Starting at the Right side, going towards the Left, on the Top row;
Starting at the Right side, going towards the Left, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
Pins 1 and 3 ( Yellow ) are for the Harddrive Activity LED.
The light in the front panel that flashes when the harddrive is actively being used.
Pins 2 and 4 ( Green ) are for the Power On LED.
The light in the front of the computer that shows when the computer is on.
Pins 5 and 7 ( Blue ) are for the Reset switch.
The Reset button on the front of the computer, IF, the computer came with one.
Pins 6 and 8 ( Red ) are for the Power On switch.
The Power On button on the front of the computer.
Pin 9 (Black) is for the +5 Volt power
Pin 10 is not used. (Not connected)
The reason I took you the long way, and did not just provide a link to the Front Panel header, is in case you need more information about your computer.
This way you'll have it.
Feb 26, 2010 | Gateway GT5428 PC Desktop
How to connect front panel plugs
You are working inside the Computer, before you connect the front panel to the motherboard, don't forget to unplug or Power Off.
To see how to connect it, here is some link for information:
www.yboyandrei.com/frontpanel
www.yboyandrei.com/usbfrontpanel
Please rate if i am helpful to you.
Thank you.
Sep 01, 2009 | Office Equipment & Supplies
Hi mubarakdream, please open your manual to page 1-6, motherboard layout. Find USB20_5 & USB20_6 page 1-14, at the bottom of the motherboard. You can plug your front USB onto these USB pins. (Careful, front & side case USB's break very easily). It only takes a slight bump to break.
Leave the motherboard jumper set to default for USBPWR_56, page 1-10.
If you need the Asus manual you can download it from this link;
http://support.asus.com/download/download.aspx?modelname=P4BGL-MX&SLanguage=en-us
If you need more information just post back into here.
Good luck mubarakdream!
Mike
Aug 26, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Front Panel Connection Problem
if you look at the PDF file here:
ftp://download.intel.com/support/motherboards/desktop/d845hv/A6513601.pdf
On page 68 you can see it more clearly. Just enlarge the file.
do you know the make and model of the case?
Nov 20, 2007 | Intel D845HV (735858149143) Motherboard
Foxconn 848P7MB-S Motherboard Logo
913 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
