Question about Dell XPS 200 PC Desktop
CD/DVD Not Working
I just purchased a Dell XPS computer in July. The problem I am experiencing is that my CD/DVD is not working. The error code that I received is as follows:
"Windows was able to successfully install device driver software, but the
driver software encountered a problem when it tried to run. The problem code is 19."
Also, since my initial report of the CD/DVD failure, I have I tried using an external DVD, and when plugged in the USB port, the computer could not detect it. There is no problem with the external DVD as it works on another computer.
The computer was purchased at Best Buy in New York and I am currently out of the country. The computer is under warranty. How can this problem be corrected. The exact product is Dell XPS M1330 and the model number is PP25L.
Ms. Lee
    Problem Solver:
  • 8 Answers
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Posted on Sep 17, 2008
  • 30 Answers
Solved my problem than u so very much
Posted on Jun 18, 2013
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
Dell xps 400 dvd/cd drive door won't eject or
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Jan 26, 2012 | Dell Computers & Internet
My dell xps one will not boot because of a disk read error problem, what can i do?
If you can boot from your Resource CD, then your hard drive is defective or it's OS (Operating System software) is corrupt and needs to reloaded. You should have a CD that came with your computer called "Resource CD" or "System Tools". Under contents of CD look for "Diagnostics". You can boot from this CD by powering on computer and selecting key to reach the Boot Menu. Inset CD and boot from CD/DVD drive.
Jan 17, 2011 | Dell XPS One All-in-One TV Desktop with...
My dell laptops xps m1330 dvd player is not working
Verify that you have the last firmware (A14) on the Dell Support web site. Then check the CSS status of the DVD (should be unlocked) with this utility
http://www.digital-digest.com/software/download.php?sid=2&ssid=0&did=1
and finally verify that the DVDs are actually readable, and that the DVD reader works (try reading / burning a data CD-ROM or data DVD).
Check also that the video player software is set to the correct region and there are no errors in the Event Viewer (Hit Start, choose Run, type EVENTVWR.MSC and Enter). DVD events should be either under System or Applications.
Apr 15, 2010 | LG GCC 4320B CD-RW/DVD-ROM Burner
Dell Dimension XPS GEN 5 IDE Philips CD DVD drive failed. So I tried a Liteon SATA CD DVD drive, but that wouldn't work. So I tried a Samsung IDE CD DVD drive and that won't work. I'm guessing mobo driver...
first try installing one and go to your bios and set your bios to default . save you changes and exit.
also in my computer look and see if it appears there
if so you know its being reconized.
rite click it go to properties and then hardware
select the drive if you have gotten this far meaning you saw the drive. . go to properties and see if it says its working properly. it could also be that none of the drives your trying to install are compatible.
Nov 12, 2009 | Dell Dimension XPS 400 PC Desktop
Dell XPS One, Vista, Seagate Hard Drive failing?
go to pcpitstop.com and run full test. But it sounds like spyware to me.
Sep 15, 2009 | Dell XPS One Red Desktop Computer
Dell XPS 200 CD/DVD reading problem?
the reade part of ur CD/DVD drive is damaged while the Burner is still ok .
1/use the cleaner disc.
2/replace the part.
3/replace the drive as a last solution.
plz do rate this post.
Dec 29, 2008 | Dell XPS 200 PC Desktop
Dvd & cd drive stoped working after an update
filtercheck 4.6 and remove upper and lower filter.
Nov 16, 2008 | Computers & Internet
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
Nov 02, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Dell Cd/Dvd burner not working properly
I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
I'm going to try cleaning it, and then just swap it out for a better device.
Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Dell XPS 200 PC Desktop Logo
102 people viewed this question
Alun Cox
