Question about Samsung LN-S4692D 46 in. LCD HDTV
T-con board for your samsung
Hi, how did you locate the t-con board in your tv? I don't have a service manual. Is an easy fix? Just pop out the old and in with the new? Can you tell me where to find it?
C.
The t-con board is very easy to replace. The only problem is you need to take a bunch of stuff off before you can get to it. How to replace it:
1. Take off the back of the TV
2. Unplug all the wires connected to the middle boards, you will need to take off the whole assembly that the 2 boards are attached to, the main power board and audio/video board.
3. The t-con board is under the shiny metal cover near the top of the TV. There are four small screws holding the cover in place. (You should be able to see the cover when you take off the back plastic cover of the TV).
4. There are 3 connectors attached to the board. The white one that comes from the audio/video board and 2 small ribbon type that connect to the front of the TV, probably the LCD panel.
5. The 1 separate connector is self explanatory. The other 2 are a little more difficult. They just slide into place. When you look at the connection, there is a brown "flap" holding the ribbon in place. You need to flip it up from the top side of the TV.
6. The old t-con board just comes out and the new one goes in.
Hope this helps!
Let me know if you have any other questions.
Ben
Posted on Sep 16, 2008
Should I repair my Samsung LCD with a T-con board replacement?
Hi, maybe before replacing T-Con board it should be better to check voltages from power supply to the board, you could google for the service manual of your TV to have the right values of voltages and the signals you could check.
Nov 02, 2015 | Samsung LN55C630 TV
How to fix LED TV
probably the T con board is faulty. T con broad is the one which drive the LCD pixels. Watch the video to identify the T con board.
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
www.electro-medical.blogspot.com
Sep 18, 2015 | Samsung Televison & Video
What component should I get to fix my Samsung LCD TV?
HI,
Probably the t con broad is faulty. t con board id the on which drives the LDC panel. I some tvs its not possible to replace the T con board as it would be integrated to the LCD panel normally in 32 inches and bellow. In others i would be separate board which is replaceable individually. I have added a video to know how to locate a t con board which is replaceable individuality. As you didn't mentioned the model number its not possible to add the exact image. In all most all the tvs T con Board (individuality replaceable one ) will be placed on the top center of the tv cover with a metal shield. If its incinerated to the LCD panel then inside the LCD protection metal chassis. Check and fin which one you have.
Samsung LCD TV Repair Identifying Samsung Con Board Part Numbers How to...
Sep 10, 2015 | Samsung Televison & Video
T-Con Board for Samsung TV
Here's a place where you can purchase a T-Con board. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 04, 2017 | Televison & Video
I have a samsung LN_T4061F and it has vertical colored lines on the right side of screen on all channels. lines are about 1 inch from side of screen and are about 1/5 inches side.
Hi there are a couple of hings that could be bad with your tv. Your screen or your t-con board would be the most obvious. Screens are expensive to replace so I would try replacding the t-con board. The t-con is the board thattransfers your signal to the lcd screen. It is usually located on the top center of the tv. You would need to open up your tv and get the part number fro the board.
You can get get parts for this tv at www.interliquidparts.com
Nov 20, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung LN46B530 LCD TV. There are 2 parellel lines on my screen, tv is 2 years old, first started with 1 thin line in the center of the screen, now that one has gotten thicker, and another one...
These lines came on to the tv LCD screen panel by itself?Yes,than the board that call the T-CON board it is dying to causes this problems,if these black lines problems causes by u or an object by hitting it to the tv LCD screen panel itself,it can't be repair,the tv LCD screen panel itself it is dead and leaking radiations.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 22, 2011 | Samsung LN46B530 LCD TV
When I turn my tv on my speakers work for apprx 5 minutes than start crackling very loudly then go out.What could cause this ?
Hi, My samsung dlp 46 tv was making a loud crackling and popping sound from the speakers, I turned OFF all the volume
control on my tv from the menu the srs, the auto tune volume, the internal volume which, is the main one which silences the crackling sound immediately! But, you must have surround sound and play the tv volume through your surround sound and wa laaaa, it WORKS! The tv may eventually stilll go out before or if I decide to have it fixed. It is about 3 years old.
Nov 30, 2010 | Samsung HLT6187SAX 61" DLP HDTV
T-con board
can purchase just t-con board online for small fee and replace yourself. ShopJimmy.com
ours went out after 5 months and it was still under warranty. samsung wanted us to send it to them and it would have cost me $70. i just bought the part online for $20. way better deal
Jun 17, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Screen Noise
Hello LNR328W
You have a bad T-con board. This board is mounted directly on the panel. Its located near the top of the set in the middle. This part is sold with the panel which makes it expensive. I have a few T-con board in stock. Let me know
Best regards
circuitcity
Jan 24, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-S4692D 46 in. LCD HDTV Logo
416 people viewed this question
Henry  Thomas
Henry Thomas
