Question about JVC Audio Players & Recorders
Problem with JVC model CA-MXDK
Hi
I have a Jvc shelf system with a DVD drive and while I was watching a movie the player just stuck and displayed "upgrade disk" message.
I coulden't be able to rest it even by unplugging the power cable.
I want some passwords
Posted on Mar 02, 2011
Jvc dvd player won't open
when you hit the eject button try tapping the top above the disk drive. it may be somewhat stuck. if that doesnt fix it you might have a broken belt or a belt may have come off in it. the belt controls the movement of the drive in and out
Mar 21, 2012 | JVC DVD Recorder - VCR Combos: DVD...
In my system the dvd disc is still ssometime
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set.
The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 12, 2010 | JVC Audio Players & Recorders
MY STEREO IS DISPLAYING UPGRADE DISK
my cd player is reading no disc on all disc players it is a 5 disc holder
Jan 06, 2009 | JVC MX-GA77 CD Shelf System
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
No dvd
i think your console has been modified...modified console will disabled dvd player...if you want to watch dvd movie remove the chip added by your technician...
Jan 29, 2008 | Sony PlayStation 2 (PS2) Compact System...
Dvd player is locked
Ideas
1/ Turn power off for a while at powerpoint for as long as you want 5mins should be fine then turn on and try again.(which youve probably done already) as well as looking up your model number on the net to attain a info on your system.
Does the remote still work if so try to find unlock in menu/setting/functions but if it requires a digit code then youll need the manual as it could have an override built for cases such as yours.
start at jvc.com/dvd5.1 surround and find your model
good luck
Clapster
Jan 28, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
No disc loaded warning message
First check the optical pick up is working or not or change with a new one.
this part is availble with JVC service provider in your area.
Jan 10, 2008 | JVC 5 Disc Progressive Scan DVD/CD Shelf...
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Error message when playing any DVD in Hi-fi
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Feb 28, 2007 | Technics SCHD560 CD Shelf System
139 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
