Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Water won't drain out of it after cycle
The water stays in the bottom of washer and will not drain out.
  • centralcusto May 11, 2010
    water will not drain after cycle
  • 2,071 Answers
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer
  • Hope this may help;
    Regards,
    VOTIT
    DON'T FORGET TO RATE;
    Posted on Sep 16, 2008
    Samsung manual download
    You may need to check the drain valve at the bottom of washer for blockages. Pull the chord at the base and let water drain out into a flat tray with towels around. Then open the drain valve to check blockages. Usually pieces of wire and hair clips and coins.
    Try to run a rinse cycle after shutting the door. See if it clears the water.
    Jul 31, 2014 | Samsung Washing Machines
    Kenmore 90 series washer won't drain and go to spin cycle
    Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
    If helped pl say so.
    Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
    Our dishwasher won't drain completely. I ran it through a regular cycle but it was left with water in the bottom.
    Have you tried canceling the cycle? To cancel, turn the on/off switch to on, then press and hold for three seconds the two buttons labeled "Cancel Drain". Keep the door closed for the next minute so that the dishwasher can complete the cycle. During this time the pump will remove any water from the washer. Also you will notice that Bosch dishwashers always leave a little water in the system to keep the seals from drying out and going bad.
    Hope this helps
    Jan 20, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
    My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
    there is a screen that needs to be cleaned out on the bottom under the wash drum
    Jan 15, 2013 | Washing Machines
    My lg model wm2277hs won't rinse water stays after washing
    you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
    Nov 02, 2012 | Washing Machines
    Won't finish cycle
    If you can't see a clean out drain on the bottom panel pull the panel off (three screws on bottom)...you will see the drain pump unscrew the clean out (get a bucket) these models won't finish a cycle unless ALL the water is out. nine times out of ten this is the problem. Hope this helps.
    Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Won't spin out the water
    If your problem is that it won't go into an accelerated spin cycle at the end, check the settings. Most washers just let water drain out the bottom when they have finished cleaning.
    May 15, 2011 | Washing Machines
    Washer won't drain and clothes stay soaked
    Can you give me a model and brand name. Does the washer drain at any time during the wash cycle?
    Will it go into a spin at all in any setting? heavy duty, normal and delicate cycle? is water not draining?
    Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
    Washer fills but won t advance to the next setting for all cycle
    Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
    Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
    133 people viewed this question
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
