Question about Euro-Pro Steam Generator EP8001 Iron
I have a Sunbeam Steam Pro iron. Because we used normal tap water, there is a build up of calcified minerals in the water tank and the inside of the baseplate of the iron itself. The iron spits out these calcified particles when I iron. How do I get rid of these deposits? thanks heaps Anne
  • Anonymous Mar 31, 2014
    White sealed box of some sort.
    Sunbeam steam master pro. White sealed plastic box in water reservoir.
Try putting straight vinegar in the water tank. Let it set until you see the deposit dissolved. Pour it out, rinse and use either some decalcified water or add a couple tsp. of vinegar to the tank each time you use it.
Posted on Oct 07, 2008
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
The iron is still working but the water not hot
There is most likely a build-up of minerals around the steam holes. Minerals are in ordinary tap water. The coat the heating surfaces, act like an insulator and prevent iron from getting hot. Clean the hot plate with a fine needle or other fine object and then put in a mixture of vinegar and water and let it steam out. To prevent future mineral build-up, use half distilled water and half tap water. If you can't get distilled water, use ordinary drinking water you can buy from your supermarket (it also cheaper). Don't use 'all' distilled water as it boils (steams) at higher temperature and could ruin your iron. Good luck.
Jan 20, 2015 | Rowenta DG5030 Iron
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
Floor steamer not getting hot
follow this steps and fix it.
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try 1800Parts.com. It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
The steam is building up in the water tank but not going through to the iron.
I suspect that the discharge holes have become clogged by calcified deposites due to hard water. You need to de-calcify the iron. Mix one cup of white vinegar with one cup of water and pour this mixture in the iron and let it heat up. The acidic vinegar should dissolve the build up. repeat until clear. forthe final, use a little lemon in a cup of water to get rid of the vinegar smell. You can prevent this by using only distilled water in the iron, but this is not really practical, so a couple of clearing runs of the vinegar/water bath each month will put this off.
Feb 09, 2011 | Tefal UltraGlide Easycord FV4256 Iron
I have a morphy richards turbo steam iron i have had it for some 2 weeks and used it 6 times and fill it with normal tap water. on using it tonight i have noticed that there are white smears been left on...
The white stain is due to mineral build up on your iron.
Try flushing the iron with a vinegar solution to dissolve the mineral deposits then purge with demineralized water. Only use demeralized water in your iron. The first time you may want to test it on a scrap piece of cloth to insure all of the minerals have been removed.
Jan 04, 2011 | Morphy Richards Irons
Steam doesnt work
A mineral buildup from your water may be blocking the holes in the soleplate of your iron. Before you do anything, read the instruction booklet for your appliance or call the manufacturer. The old remedy of using vinegar to unclog an iron is no longer recommended for many models. Some manufacturers suggest alternating tap and distilled water in the steam compartment to avoid a mineral buildup; others recommend using a specialized cleaning product (available at fabric and grocery stores) to clean the soleplate.
Nov 17, 2007 | Sunbeam 4214 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
158 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
