Question about Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22)
AGP Video card for P4VMM2 motherboard
I tried to install a driver for my video card agp 8x. But it is not working. Is it possible that I need an old version of driver befor my new one could be recognized by my computer?
Please help. Thanks.
  • atticcare Feb 17, 2009
    p4vmm2 v1.3 8xagp card causes blank screen on startup, both 9600xt and hd3450, cause this. supposedly wont power them???? has adjustable agp voltage driver with NOOOO explanation as to the voltage just stupid letters. So can you change it to appropriate voltage for cards???? or just use pci video card???? or just maybe an agp 4x or less only card????
  • Anonymous Mar 20, 2009
    I can't use AGP 4x card, Sapphire Radeon 9600 256mo on this board, I changed my motherboard for this reason.
  • 505 Answers
No it should recognize it strait away
You May have a faulty one
hope this link can help you thanks
Regards; Aaron
Posted on Sep 16, 2008
    Problem Solver:
  • 10 Answers
But can you see the bios..if can but hang when loading it is grapics card burned
Posted on Sep 06, 2009
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Oct 27, 2009 | ASUS P4B533 Motherboard
Problem with Video on motherboard Gygabyte 8VM533M-RZ
The answer is a definite YES. By definition of the AGP set standard, 8x gear absolutely must be backward compatible to 4x.
Any 8x card in 4x-only mainbaord, or 4x AGP card in 8x capable motherboard must and most definitely will work.
May 24, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Problem with k7s41GX
try to check your RAM.. maybe your ram is LOSE connection or physically damaged.
Feb 04, 2009 | Asrock K7S41GX Motherboard
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Dec 30, 2008 | Nvidia GeForce 6600 256MB 8X AGP Video...
Upgrading VIDEO CARD
If your motherboard's graphics slot is AGP and your graphics card is AGP then it should be fine if your motherboard is PCI-E and graphics is PCI-E it also is fine make sure your motherboard and graphics are compatible.
May 29, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Brand new geforce 6100 pm -m2
This is for the EliteGroup P4VMM2 motherboard. Please remove any newly added video card. One done boot the PC. Windows should load & function (Including video display). Yes?
Restart the PC & press the delete key every 2 seconds untill the bios menu loads. Opem the manual to page 33. Change the Primary Graphics Adapter from PCI to AGP. Save & exit the bios. The system will begian to restart. Press & hold the power button untill the PC shuts down. Unplug the power cord from the PC. Install the AGP card & connect any additional power to the video card if required. Double check all data & power connections for good fit before closing case. Re-connect the power cord & start up the PC. You should have display. Allow windows to finish loading & install the AGP software. Than update windows.
Who ever heard a single long beep. This means the video card may not be seated fully & or correctly. Remove the AGP card, blow out the AGP slot with canned air. Take some alcohol dripped onto a cotton swap. Clean the AGP's copper contacts & clean/wipe the copper within the AGP slot as best as possible. Allow time for alcohol to dry. Re-insert the AGP card, firmely & evenly.
Any more troubles? Please list the issue here. Need manual for the EliteGroup P4VMM2? Click on this link:
Good Luck!
May 18, 2008 | EliteGroup P4VMM2 Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site:
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
u have an agp slot on the motherboard. no good latest cards come on agp. go for a geforce 6200 agp. shud be able to find that at very low price.
Dec 05, 2007 | Computers & Internet
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
Pioneer ECS P4VMM2 V3.2A P4(478)/FSB 533/VIA/SDRM+DDR/A&V&L/MATX Motherboard (MBEP4VMM22) Logo
529 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
