Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Maytag neptune mlg2000aww super stacker washer stopes at each cycle and turns off
When I turn my washer on it goes through the first cylce(wash) and then turns off at the rinse (1). I turn it back on and then it stops and turns back off at the rinse(2). I turn it back on and it continues to turn off again at the rinse(3).Then I have to turn it on for a final time to spin. It started out only needing to be turned back on once, but now I have to turn it on again at each stage. What could be the problem?
Also my fabric softener and bleech compartments are filled with water and don't empty. when I manually empthy them they fill with water when I use the machine again. Any ideas about what the problem could be with that?
Thanks!
  • Anonymous Oct 09, 2008
    I have exactly the same problem. I can do a load of wash if I check every few minutes and hit the start button when it stops. The repairman I called said he doesn't know what is wrong. I really don't want to have to purchase a new machine. Can anyone help?
  • brmeca Dec 27, 2008
    We have the two exact same problems with our machine. Of the two, the machine stopping frequently is the most frustrating! Sometimes it seems we'll have to push the start button eight or ten times just for one load of wash. Suspect the timer (washing machine cycle selector) but don't want to replace it without knowing for sure, as the part is fairly expensive. With this being a somewhat common problem, am a bit surprised there is not more information available. Any suggestions would be very much appreciated. Thank you.
  • 3 Answers
SOURCE: Maytag Neptune mlg2000aww
SOUNDS LIKE SOMETHING STUCK IN PUMP
Posted on Oct 24, 2007
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
SOURCE: Neptune stackable washer...
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
  • 163 Answers
SOURCE: Won't run
sounds like your lidswitch.when you close lid you should hear or feel it click on and off.located on back side of lid in center.
Posted on Mar 10, 2009
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
It goes off balance in the reverse cylce. I just put a new clutch in.
"" it goes off balance in the reverse cylce. I just put a new clutch in. ""
Is that the Spin Cycle? Wash basket is rotating CCW is that correct?
Did you follow this post for the Clutch replacement?
I
Sep 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune stacking washer, model #MLG2000AWW, sounds like a jet engine warming up during spin cycle. Otherwise it is quiet and works well. Is a main bearing going out? Is it something I can fix...
you can but it wouldnt be economical to fix it if it sounds like a jet it is yr rear bearing and although the part might be only 60 dollars the amount of time it would take someone to do the job correctly is about 2-3hrs if you can do the job yourself then you would save on a large labor bill ive seen some techs price doing this job at starting prices of 400 you can find the part at marcone appliance parts if you choose to do the job yrself hope this helps
Jul 18, 2010 | Maytag Washing Machines
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mlg2000aww door will not lock or spin
Removing the top cover of the dryer, you will find, in the front right, the machine electronic control board with a burned resistor. This resistor burns up when the washer lock motor fails. The lock motor and control board will need replacing. Parts cost will be around $220.00.
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune mah7500aww adding water to wash cycle problem
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
Jun 06, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
154 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
