Question about HP Computers & Internet
Cleaning screen without leaving marks - HP Computers & Internet
  • 1,498 Answers
Barring anything 3D stuck to the screen, try this:
My secret weapon...... Newspaper.
Serious. Use any window cleaner and a crumpled up sheet of old newspaper (black and white only). Have a couple sheets ready. Spray, wipe with one, dry with the second. It doesn't leave anything to evaporate, therefore, no marks. Works great on windows and mirrors too.
I can't tell you why it works, it just does. Try it with the leisure section. If you find it works as good as I say, please take a moment to rate this response. Hopefully, I didn't sound too much like a detergent commercial.
Regards
Mike258
I
Posted on Sep 16, 2008
    Master:
  • 505 Answers
News paper and window cleaner is the best with no regret's
No Marks no smudges super clean
Regards; Aaron
The vacuum leaves roller marks,
check the small black plastic rollers in the head are rolling freely
if not replace them
Oct 22, 2016 | Vacuums
Dusting dark walls without leaving marks
have you tried lambswool?
or wetting down the cloths first.
or.......change color! ;)
Good luck
Neil
Mar 30, 2014 | BEHR Premium Plus Ultra Paint. 8 oz. Royal...
I cleaned the projector screen but it is leaving a water mark what do I do
You may have damaged the screen if whatever you cleaned with has chemicals---most screens have a protective anti glare coat that is easily damaged----If a streak is there it is likely this is what happened.
Nov 04, 2012 | Televison & Video
HOW DO I TURN ON THE LAPTOP WHEN THE SCREEN IS BLACK AND THE BLUE LIGHT BUTTON IS ON
This problem can happen after using the disc clean up tool which can disable the hibernation file. Try the following:
Click start>all programs>accessories. Right click command prompt and click run as administrator. Type: 'powercfg -h on' (without speech marks) in command window and hit enter. That should enable the hibernation file and hopefully solve your problem.
Mar 13, 2012 | Computers & Internet
My 3 year old niece touched the centre of my panasonic viera plasma screen leaving a grey "burn" mark - how do I repair or clean it off?
That will be just a discolouration, not a burn mark.
Use dilute washing up liquid and a soft clean cloth that has been wrung out almost dry, to wash the grease marks away.
Hope that helps.
Jan 15, 2011 | Televison & Video
42" LCD TV leaves marks on screen following using
This is a defective LCD display panel. It will cost as much as a new set unless your still within the 1 year warranty. As far as cleaning the screen, you can use an old t-shirt by spraying a little windex on the shirt and wiping gently up and down or left to right but never in a circular pattern. I found it best to do this after the set has been on for 15 minutes to warm up the surface then shut the set off and give a clean.
Nov 27, 2010 | Televison & Video
Finger print marks on the screen
you mean clean the screen ??
any solution designed to work with perspex or acrylic will be perfect. try "uvex" products or those designed for perspex motorcycle crash helmet visors.
i had a few rear projection tvs over the years and normal everyday household polish didnt do mine any harm at all.
also a damp cloth will remove fingerprints but will leave smears. so skip the washing stage and just use an everday household polish without beeswax in it ,cos that puts a waxy coating on it. stay away from any alchohol based products.and if in doubt try the uvex stuff
http://www.envirosafetyproducts.com/product/Uvex-Clear-Lens-Cleaning-Solution-16-ounce-Pump.html available outside the us as well, made for cleaning safety glasses,
Feb 07, 2010 | JVC HD-61Z575 61" Rear Projection...
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Moisture behind screen
It is difficult to clean/remove the screens. Best case senario, it will dry up leaving little to no water mark. There are three screens, liquid gets between them and it sucks it in. Disassembly and cleaning will fix, but the screens are very fragile and cannot be wiped without potential damage. Any dust, dirt between them will show in the picture. Proceed at your own risk.
Sep 04, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
MARKS ON SCREEN
there are two screens..the lenticular..and the fresnal...you can try to pull them apart(very fragile!) and clean them but you must be careful not leave any water or moister between them(blowdry or wipe completely dry after cleaning with damp cloth) do not rub too hard...just spray warm water on the rag and carefully wipe clean ...then dry. Putting the screens back together isn't too tricky but let me stress..these screens cannot be bent or they will break...pull them off with two people(one on each side)..also you will have to take the front cover off because the screens are literally clamped down to the front cover.....good luck...let me know if you need futher assistance..........mike
Feb 13, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
Computers & Internet Logo
88 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
