Hp 530 notebook flashing power light when unplugged from the power cable, even though the battery is 80% charged
  • 1 more comment
  • carobelle Jan 19, 2009
    compaq presario c500 the power light keep flashing orange
  • davez79 Jan 26, 2009
    My battery light flashes all the time when unplugged and on. What is it and what do I do?
  • chiqy May 03, 2009
    I have the same problem, before when i remove and reinsert the battery it would stop...now its more persistent and it acted up right after the warranty period. Someone who had the same kind of machine told me its the beginning of trouble and it will start going off on its on etc etc....if this is a malfuction of the model what options does one have to have HP sort it?
    thanks
Hey
i had this same problem with my hp 530
i dont know if this is what you are meant to do but if u turn off the laptop and take the battery out and put it back in again the problem should stop
it may happen again a few weeks afterwards but just do the same thing
Posted on Jan 15, 2009
I have now come across two identical c500 presarios owned by different people with exactly the same flash amber light problem. Taking the motherboard battery out to reset the cmos failed to fix them. Also a search on the internet came across many other people with this. Unfortunately it seems like a component fault somewhere in the power supply circuit. When I get some time over xmas I'll try to trace it. Untill then I recommend to people "dont by compaq they are cheap ****", just my oppinion.
Posted on Sep 25, 2009
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
When I plug in my HP 530 Green light comes on then turns to amber. Will not come on even when I remove battery and just plug in. 1322dijim@gmail.com Posted by Guest on 7/5/2012 Details My notebook wi
The amber color of the light is an indication of a motherboard malfunction ..and this is the reason it does not work ...It can be something related with a poor contact or a CPU issue ..but usually when this light is on ...it means you need a motherboard for it cause the one in discussion is dead ..
Jul 05, 2012 | HP 530 Notebook PC
The System / Motherboard has faulty Power Circuit. Contact HP and arrange a repair. If under warranty won't cost anything.
HP LAPTOP YELLOW LIGHT ON ALL TIME EVEN WHEN CHARGING BATTERY
Suspect the battery needs replacing as it should only change color when the battery has reached full charge. For the yellow to stay on it indicates either a fault battery or the way the battery is reporting it's condition. Check HP website for your battery number for recalls or issues.
Dec 18, 2009 | HP 530 Notebook PC
Installed wrong version bios on HP 530
u can try reseting the BIOS.onlyt option is taking out the CMOS battery and then putting it back but in tat case u hav to open up u r keyboard ,,its a bit risky,,so u better call up tech support for locationg the CMOS battery
May 14, 2009 | HP 530 Notebook PC
Laptop turns off intantly, when I unplug the charging cord
For those of you having the problem of a HP laptop shutting off when you unplug the charger and your battery is fully charged, I can help you. There is nothing wrong with the laptop, battery, or computer, it is a power management setting. If you go to display properties, select the screen saver tab, then click the "power" button, in the power schemes field is a drop down window, click on it and select "Rixane Power Scheme", it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on. If you have it set to "always on" it will shut off when you pull the power cord, even if the battery is charged. This will also happen on many non-HP laptops, if you don't have a HP laptop or there is not a "Rixane" option available, select the "Portable/Laptop" power scheme. Hope this helps!
Dec 27, 2008 | HP Pavilion dv9000z Notebook
Power/battery problem
hi, try removing the batt press and hold the power down for 1 minute, dont replace battery yet, plug in charger, boot up then shut down. replace battery and boot.
if this fails you could also try changing your power settings in control panel. change to minimal power managment.
remove the adapter while laptop is on and allow to completly drain(untill it switches off)
then try reboot.
Dec 19, 2008 | HP 530 Notebook PC
On HP 530 notebook battery/power indicator is always on as long as battery is connected and even when ac power is connected the situation is still the same.
Clarification of your battery/power led indicator:
Solid amber:
Battery is charging at 0% - 89% capacity
Solid green:
Battery is charging at 90% - 99%
Blinking amber:
Battery is low
Led is of:
Battery is charged
Dec 04, 2008 | HP 530 Notebook PC
Electric light flashing
This indicates that your battery isn't functioning properly or is going bad. You need to replace the battery. Bateries are batteries, some are better than others and some wear out faster than others, even though they may be the same brand, eventually all batteries need replacing.
Jun 20, 2008 | HP Business Notebook 530
Hp pavilion dv8000 help
Find out how to open up your computer youself and where the wires run from your ac power plug to motherboard has a little socket it plug. sounds like it is not connected. lol, free advice. Just plug it in
Nov 07, 2007 | HP Pavilion dv8000z Notebook
Computers & Internet Logo
2,291 people viewed this question
David Payne
David Payne
