Simpson Esprit 650 6.5kg Washing machine, top load. Doesn't accept cold water when set to cold. When switch pulled to on at beginning of cycle the agitator activates sometimes and not others. Same with the spin cycle.
I have just had the same problem occur with my washer.
I found that the hot would work but the cold would not.
The fault is the cold water valve.
This is the part that the hose screws to at the back of the machine.
To have a look at it unscrew the top of the controls at the back and you will
find the valve.
Follow this link for the part.
http://www.alliedappliance.com.au/info/A864810001.html
Posted on May 21, 2009
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
Simpson washing machine will not fill
faulty control board or timer
Nov 19, 2017 | Washing Machines
How do I get my washing machine to spin
Check the interlock tab (upright models) or the hinge or latch switch (front-load.) Sometimes these switches break or simply come loose.
Aug 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
Feb 09, 2012 | Simpson Esprit 750 Top Load 7.5kg
Hi, Weve got a simpson esprit 700 washing machine and the cold water tap seems to be blocked. I've disconnected the hose at the washing machine end but when I've turned it on in the sink it works fine so...
Hi just read your posting.There are 2 types of SIMPSON ESPRIT washing machines,There is a top and front loader version.Which one is yours?Please reply and I will guide you on replacing the water valve.Looking forward to your reply.
Sep 19, 2010 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Mar 31, 2010 | Washing Machines
THE TECK SAYS THAT THE SIMPSON ESPRIT WILL ONLY
you can pick up a Y adaptor from a hardware store and fit a cold feed to both, it will take a few more minutes to comlpete cycles thats all, all new machines are fitted with a cold feed only to make them more energy efficent. the tech is talking pi**
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
1,181 people viewed this question
Top Washing Machines Experts
