Question about Dell PowerEdge 2600 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
We have Dell PE 2600 with 32GB of hard disk. The disk is full , and we are considering of buy ing a new one. Can we add 142GB to existing 32GB
Thanks
    Novelist:
  • 159 Answers
PE 2600 has 6 drive bays, organised as either one set of 6 or 2 sets of 3 .
Normally the drives are arranged in a 'RAID' configuration (at least 2 drives, one of which can be allowed to fail and be replaced without loosing your data)
... however if you have only a single drive, plainly this is not possible and you can add whatever additional drives you like ....
Posted on Nov 29, 2008
    Scholar:
  • 95 Answers
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Posted on Sep 17, 2008
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
Ran Dell diagnostics and SATA Disk Confidence test failed, Error Code 0F00 1332,Disk Block 30819848(etc)IRQ did not set in time. Dell Inspion 1545 laptop with SATA disk s/n 5VC2W51X
consider to replace your hard drive, your hard drive detected crash on your bios so you have to replace it. your hard drive can be use to external hard drive buy some external hard drive case 2,5"
you can re partition your hard drive and maybe if you are lucky the harddrive can be use again on your laptop
Jan 16, 2011 | Dell Inspiron 1150 Notebook
Dell poweredge 2600 wont load anything from hard-drives what do i do?
Go into CTRL-M, go to Configure>View/Add, accept and save Disk View if prompted, and check the status of each drive. What is your RAID configuration (F3) and the drive statuses? If you are in the States, call Dell support 8008228965 - it is free whether in or out of warranty. It will be much easier to explain what you see.
Mar 14, 2010 | Dell PowerEdge 2600 Server
My 40 GB hard disk got crashed for KOB 810e FST Mother board. can i use new 80G or 160 GB hard disk. does my mother board supports 80 GB or 160GB hard disk. I have 256 MB of RAM. can i upgrade it to...
Yes, any motherboard that supports "larger-than-32GB" disk-drives should support larger disk-drives.
Yes, most motherboards support up to 512MB per stick of RAM.
Jan 02, 2010 | Intel Computers & Internet
Ide controller for dell inspiron 2500 laptop
Any 20GB disk-drive has built-in drive-electronics,
which interface with the IDE hardware on the motherboard of the laptop -- typically, laptops do *NOT* have "plug-in" adapters for such "basic" functions, unlike desktops, where you can change video/audio/network hardware via add-in cards.
You probably can use any disk-drive that is _smaller_ than 32GB -- disks larger than 32GB require newer motherboards, due to the larger capacity of those disks.
Dec 11, 2009 | Computers & Internet
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
Epox motherboard and SATA disk
According to the hard drive manufacturer Maxtor, motherboard host controllers using the VIA and SIS chipsets VT8237, VT8237R, VT6420, VT6421L, SIS760, SIS964 found on the ECS 755-A2 manufactured in 2003, do not support SATA 3 Gbit/s drives. To address interoperability problems, the largest hard drive manufacturer, Seagate/Maxtor, has added a user-accessible jumper-switch known as the Force 150, to switch between 150 MB/s and 300 MB/s operation.[9] Users with a SATA 1.5 Gbit/s motherboard with one of the listed chipsets should either buy an ordinary SATA 1.5 Gbit/s hard disk, buy a SATA 3 Gbit/s hard disk with the user-accessible jumper, or buy a PCI or PCI-E card to add full SATA 3 Gbit/s capability and compatibility. Western Digital uses a jumper setting called "OPT1 Enabled" to force 150 MB/s data transfer speed. OPT1 is used by putting the jumper on pins 5 & 6. http://en.wikipedia.org/wiki/Serial_ATA
Dalius
Mar 30, 2009 | EPoX EP-8K9A7I Motherboard
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
Dell poweredge 2600 upgrade
Look at the service tag on the unit and go to support.dell.com to get the specs on the exisitng drives. Mine came with Seagate Ultra320 SCSI 80Pin 15K drives, You can shop for the 146GB versions and use your existing caddy's if you would like.
May 27, 2008 | Dell G6632 146 GB SCSI Ultra320 Hard Drive
New HD
What controller do you have and are you doing JBOD?
Oct 30, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
237 people viewed this question
Alun Cox
