System error when i start my pc there is a message showing "system error -the IP address is used by another network"
You need to change your IP. There is a system on the network using the same IP with your system.
Posted on Sep 16, 2008
System IP Address not found and says Media is Disconnected ? I have tried ipconfig /release and ipconfig /renew but didn't get result...Please solve this problem
Re: Communications
Background
  • IP addresses are four numbers separated by periods. The four numbers can each range from 0 to 255. They are used on the Internet and on local networks. A current Internet IP address is 74.59.119.24. Local network IP addresses all start with 192.168 and an example is 192.168.0.101.
Identification
  • When the IP address of each computer on the network is checked, two will be the same. The IP address of a computer can be found by running "cmd" and then "ipconfig" in the black pop-up box which appears. Each computer will show an address like 192.168.xxx.yyy and two will be the same, resulting in the conflict message.
Solution
  • The IP address of one of the two machines which has the same address will have to be changed. IP addresses are set in the Network Properties section under Protocol (TCP/IP). The last three numbers of one of the conflict machines must be changed to a number different from all the other IP addresses. The machine must be restarted and the error message will no longer appear.
Jul 30, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
How do I find my ip address?
In windows 7, xp, vista:
START, ALL PROGRAMS, ACCESSORIES, COMMAND PROMPT
type in ipconfig,
ENTER,
IP IS SERIES OF NUMBERS
if you are using ppp with modem then will change every time you log in.
Mac OS X computer:
APPLE MENU, SYSTEM PREFERENCES, VIEW MENU, NETWORK, IN PREFERENCE, NETWORK PORT,
if you are connected it will be there.
OS X 10.4 OR 10.3:
APPLE MENU, LOCATION, NETWORK PREFERENCES, SHOW, NETWORK STATUS,
Sep 06, 2012 | Dell Computers & Internet
How to fix Ip address conflict problem?
This is due to same IP address has detected in the same network. Change your local PCs IP address by clicking Settings > Network Connections> Local Area Connections. Right click on Local area connections and Properties > Select Internet Protocol [TCP/IP] > properties > Use following IP address enter new IP address (eg; 192.168.0.250). Let me know for further assistance
Feb 17, 2012 | Computers & Internet
I have one error my error is: there is an IP address cnoflinct with another system on the network
"IP conflict on Network" -> means your have 2 or more clients (PC terminals) having the same IP addresses on a workgroup on the Network!
You have to reconfigure your network TCP/IP settings from your Network Connections. You can reconfigure the settings using "Obtain an IP address automatically & Obtain DNS server address automatically or do a manual settings using alternate configurations"
Hope it helps.
For the not so tech savvy users it is quite complicated.
Nov 13, 2010 | Computers & Internet
Windows system error: "an IP address conflict wit...
This error indicates that you have two devices on your network that have the same ip address assigned to them.
If you have have ip addresses manually assigned to your network devices you can open a command prompt and enter IPCONFIG, this will tell you what the ip address is of the device that is giving you the error. This ip address is assigned to another device on your network.
You can either change the ip address of the device you are receiving the error from or find the device with the same ip address and change that one.
Alternatively, if you have a router that that has DHCP enabled you can change the properties on your network adapters to obtain the ip address automatically by going to Network Connections, right click on LAN connection and click properties.
May 21, 2010 | Computers & Internet
Sharedaccess_nat
go command prompt and type ipconfig /release
and enter
then press ipconfig /renew
and try to restart the system and try
Aug 12, 2009 | Computers & Internet
Internet connectivity
TCP/IP network transport not installed
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000 __________________
Bob Lin, MS-MVP, MCSE & CNE
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
Oct 17, 2008 | HP PAVILION A6230N DESKTOP PC
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Belkin Parallel AutoSwitch F1U115E
Please advise of further info. All the connected PC's are running on XP. One is not connecting to the network. Sounds like the "Local Area Network" setting needs to be set for "Automatically assign an IP". Go to the start menu, select "Run" and type in "CMD". Type "IPCONFIG" and enter. This will display your network setting and IP address. If there is no IP address, then you will enever have a connection. If the IP address is listed, it will display a unique IP address, a subnet of 255.255.255.0 and the ip address of the gateway. Please respond with any further.
Jan 24, 2007 | Belkin F1U115E Parallel Switch
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
