Question about Epson Stylus CX6400 All-In-One InkJet Printer
Color printing problem
I installed all new ink cartridges and only the blue is printing no matter what ii try
  • Anonymous Sep 24, 2008
    how do u clean the heads do u take it appart and clean them my cx6400 works but prints blank pages
    Sergeant:
  • 399 Answers
It is because of the clogged nozzles of other colours.even sometimes cleaning the head does not solve the problem.the nozzle needs to be cleaned by servicing it manually by a proper technician.thanks.
Posted on Sep 16, 2008
Printer wont print it has a new black ink cartridge but the color inks has no more.how can i print black only.
You cannot print unless both cartridges are installed and have a decent supply of ink left in them. It doesn't matter if your printing only black and wont need to use the color cartridge. It still have to be installed with ink for your printer to work. There is no way of getting around this problem.
I wish I had better news for you.
Nov 10, 2010 | HP Photosmart C7250 All-In-One Thermal...
I just installed a brand new HP 17 color cartridge in my HP deskjet 845c (as it appeared that the old one had run out of pink and yellow color) and now the new one will only print out in blue. I took out...
One of the first things I would do is called "footprinting" the cartridge. Remove the cartridge from you machine and firmly press the bottom of the cartridge, the print head, onto a paper towel. Use your other hand to apply even pressure from underneath the paper towel. This, hopefully, will cause ink to bleed out of the cartridge and onto the paper towel. Be aware that you may get ink on you and take measures to prevent it if necessary. A good footprint from that cartridge should yield three small rectangles of the three colors in the cartridge, it is ok if they bleed into each other. If cyan is the only color flowing you can try moistening the paper towel with some warm distilled water and gently holding this against the print head for a short while (30 sec), again ink should come out. If there the cyan is still the only color to flow there is nothing more you can do at home. Return the cartridge if you can.
If however all three colors footprint well then it may be a driver and/or firmware issue with the printer. I would try reinstalling the driver first, then upgrading the firmware is an upgrade is available. Those machine are getting older and probably do not have as much support available as newer machines do.
Mar 24, 2010 | HP DeskJet 845c Printer
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
My Epson stylus 84 color printer is only printer the color blue
Hope you have installed a original ink.
Take the cartridge out, wipe the extra ink on the cartridge and carrier with little alchole and cotton. and reinstall the cartridge back.
Print a test page and let me know
Kevin
Apr 06, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
New color cartridge won't print in correct color
Was this a new factory ink cartridge or a refilled one?
I have seen some reconditioned/refilled with the color inks refilled in the
wrong section.
Sep 25, 2008 | HP DeskJet 812c InkJet Printer
Epson Stylus CX6400 All-In-One InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
