Question about HP iPAQ H5555 Pocket PC
5550 not powering on
I got an old ipaq 5550 which seems to be just dead but was working befor put on storage. I bought a new battery. I tried hard reset, but sill charging light is not flashing and power button does not seem to work. any ideas somebody?
  • 2 more comments
  • thomasge Sep 16, 2008
    yes, exact replacement battery and no, it is not working with either one connected to the cradle and power....
  • buffy7288 Feb 01, 2009
    My Hp5555 wont power on or charge. It was wokring when I put it way for storage. I decided to take it out of storage and charge the battery. I tried the soft reset to reactive the battery. I took the battery out and reset the unit. Then replace the battery and placed it on the cradle. Did not work. Then I took the battery out again and held down the power button. Replaced the battery, and pluged in the ac adapter, still nothing. Please help...
  • Anonymous Mar 14, 2009
    the screen won't turn on when I charge it .also when i try to turn it on it won't work.but it has been in storage for a while.
  • Anonymous Mar 23, 2009
    I have a hp555 with the same exact issue. New battery but will not turn on. I have charged the unit for over 24 hours. When I hit the reset button it will go through the intro screen for a couple second then just shut off. No matter how many re-boots the unit will only power on for about 3 seconds.
  • 659 Answers
Was the battery a exact replacement to the one you removed?
also do you have the power adaptor for it put the old battery back in and see if it will run off the adaptor with the old battery plugged in and then you know the issue is with the new battery and not the unit itself.
Posted on Sep 16, 2008
  • Wesley Gardner
    Wesley Gardner Oct 02, 2008
    hmm sorry I thought about it for quite some time and it seems to me there is a issue on the board on the unit not allowing flow either a blow resistor or capacitor. but I could be wrong. would have to look further into it to be able to tell
My screen is not visible after I put my HP iPAQ HW6915 in my pocket.
very old device, nobody uses today, its obsolete really
not supported.
why ask here, , why not ask at HP.com
the real deal , HP. we are NOT HP, at fixya.
https://h30434.www3.hp.com/
a new battery? tried?
Jul 28, 2017 | HP iPAQ hw6915 Smartphone
IPAQ 5550 can I override the pin number?
Simple Solution:
Perform a hard reset and then attempt to login repeatedly (10x).
You will then be prompted if you wish to reset the pin entirely.
Good luck,
-AndyPants-
Jun 15, 2009 | HP iPAQ H4150 Pocket PC
Replacement Battery
PDA 2005 (as old as)
bad power supply ( weak)
bad battery charger chip inside.
this device has no value, really, why spend hard labor on such old tech? if compelled, buy 2 or 3 other dead 4360s ones, used off fleabay
to get one good one.
There is no PC made that will not fail.
consider this, if you had 2005 Toyoto car and the alternator went
bad , as all do about NOW. do you Boycott, Toyota.
nothing made by man lasts.
even earth is doomed, but not in 11 years.
Apr 16, 2017 | HP iPAQ h6315/h6365 Pocket PC
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Red Light on nothing else works
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Dec 01, 2006 | O2 Xda IIs Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
My H5450 won't charge!
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Sep 08, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H5555 Pocket PC Logo
390 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
