Question about Brother Office Equipment & Supplies
Have inserted new black ink cartridge, but not any other ink cartrige and my printer will not accept it
    Scholar:
  • 65 Answers
Some printers are proprietary, meaning any cartridge won't work even if they look the same they have to be purchased from the manufacturer of the printer.
Posted on Sep 16, 2008
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
After changing the cartridge the Black in is not working
Your printer's head mainly (black holes) may be block by dry ink. Try to clean it. To clean follow these proces:
Take black ink in a plastic seringe Then unplug black cartrige. See inside into cartrige carrier. There is a black plstic stick. Try it to insert into plastic seringe (carefull). Then push ink through black stick. ( 4/5 times) . After that you will be relive from your printer problem.
Thank you.
Sep 11, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
How do I change the ink cartriges in my printer
1.Turn on your printer.
2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
3.Press down on the ink cartridge lever to raise each ink cartridge lid.
4.Remove the old ink cartridges.
5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
6.Snap each lid closed.
7.Lower the scanner base unit until it is completely closed.
Enjoy printing...
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
I have inserted both my blacl & colour cartriges properly but still my printer is showing some problem with my black cartrige
When ink cartridges get low they can dry out if you do not print that frequently. So try a new cartridge. Make sure that the carriage is clean, wipe down the copper contacts on the carriage under the black cartridge with alcohol. Also ensure that the cartridges themselves are not all coated in ink.
Dec 03, 2009 | Office Equipment & Supplies
Don't acept cartrige of ink. Allthe time the
this happens when you insert fake cartridges in HP. usually i think higher products of HP dont accept fake cartridges.
Go for vivera inks. they are genuine HP inks.
or look out for pin in the cartridge area. as it may not be settled properly
Dec 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My ESP 7 printer will not accept that a new black ink cartridge has been inserted. I've tried 2 new ones, same with both.
Black ink cartridge is not recognized. I installed a new cartridge last week and had no problems printing till 2 days ago. What can I do to resolve this?
Sep 13, 2009 | Office Equipment & Supplies
Query msge: Insert black or photoprint cartridge in right stall
REMOVE both cartriges then insert it again correctly in proper places
May 06, 2009 | HP Officejet 7210 All-In-One InkJet...
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
