Hitachi 53SBX59B 53 in. Rear Projection Television
Problem for Hitachi 53SBX59B 53 in. Rear Projection Television
Vertical collapse of picture then no picture
By skotkolr on Sep 16, 2008
Hitachi 53SBX59B Rear projection tv .
the unit powered up once and I took it into video chroma adjust mode
several values were not at the specified factory settings so I reset them to the service manuals specs, however on pg 6 the 1st line after v only had 1 hex value not two like in the service manual, also in pg 4 or 5 I cant remember, the first value on the hex set was rolling it would not stop maybe dc tc point, after setting these as best I could and setting the rest to factory specs the tv worked for a short time but the vertical height was not stable and was slowly collapsing (falling down the screen) , after a few min the screeen collapsed into an eye shaped collage of colors then the tv lost picture then came back then off etc a few times . now it will not display any image at all. any ideas would be appriciated is this a problem on the pow/def board or the signal board? I can get both replaced but I only need one I think. thanks
Solution #1
posted on Sep 16, 2008
Somewhat Helpful)
experttv
Rank: Guru
Rating: 88%, 108 votes
You most likely don't need to replace a board. You should solder the bottom of the vertical output, it probably has bad connections. If you don't know where the vertical output is, give me a model number and i will give you a location, or take a picture of the deflection board and i will circle it.
Tim Nolan
Was this helpful?
Yes
No
Popular Solutions for Hitachi 53SBX59B 53 in. Rear
Questions and Unsolved Problems for Hitachi 53SBX59B 53 in. Rear
Do you recommend Hitachi 53SBX59B 53 in. Rear Projection Television?
Answer
Answer
My Hitachi is fine when I play videos or DVDs but is snowy when I using Cable TV. The Cable company... (More)
Answer
I'm trying to connect the wii to the component jacks the green, blue, red input 2 and the screen... (More)
Answer
I have a Hitachi 53SBX10B AND SOMETIMES IT HAS COLORED LINES ON THE SCREEN AND I CAN TAP THE TOP AND... (More)
Answer
Hitachi LS DMP850N 8GB Multimedia Player display problem. I can view 17 albums through My Computer... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , MN
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
