Question about Zenith Z25X22S 25" TV
No Picture When I turned on the tv today I recieved a full picture for a while then all of a sudden i got only a thin linein the middle of the screen with sound onlyThe tv is a 90s model zentih model z25x22s Know when I turn it on i have a thin line green in color horizontal across the middle of the screen..help please
  • 4,234 Answers
This is a problem with the vertical circuit. If you can solder, you should be able to fix this. With teh unit unplugged, open up the back and locate the vetical IC. This should be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering hte pins. If that fails to resolve the problem, replace the IC. I will look up your specific model and try to get more details.
Dan
Posted on Sep 16, 2008
Tv had thin black line when turned on today whole screen scrambled
need to access the ez menu to reset the parameters u will need a tech to fo this
Jul 19, 2013 | Vizio VF550M 55 in. LCD HDTV
When I turn my Sanyo tv on all of picture is fit into one thin part of the middle of the tv
check the aspect , screen size u have chosen u want full screen i think ur on 4.3 which is the wrong setting for your tv xx
Feb 22, 2013 | Televison & Video
A thin white line horizontally in middle of screen At first could wiggle the cable conection on back of tv and it would go back to full screen now it won't
it sounds like you have horizontal colapse a very complect repair try hitting the tv if the screen comes up full picture then its a dry joint if not there is an ic or power fault toss it
Jun 18, 2010 | Sanyo DS25390 TV
Only have a thin line in middle of tv screen. can sometimes bang on the set and recieve a full picture
there will be a loose contact in vertical section of your tv, resolder the legs of vertical ic...with the help of atech person
Apr 10, 2010 | Toshiba 36A40 36" TV
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
102 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
