Question about Electronics - Others
8GB TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION
Hi, Im Sanjay.
Pls help me. I have bought an 8GB Pen drive and I can store about 3Gb of info on it. If it exceeds this, there is a pop up of write delayed and remove write protection. In fact it is not write protected. But how can I remove all this and use my pen drive normally.
Thanks for your valuable help.
  • 5 more comments
  • baskiatit Nov 19, 2008
    Write
  • maildatabase Nov 27, 2008
    I too have the same problem, file system shows a unknown. but drive gets detected as usb/removable device, but when i try to open or explore it says please insert a **** in drive.
    I havd formatted the drive with NTFS and it was working fine for 2-3 days. suddenly it happended. Help please
  • Anonymous Nov 28, 2008
    I HAVE 4GB TRANSCEND PEN DRIVE AND I HAVE TRYED EVERYTHING BUT ITS STILL WRITE PROTECTED WHEN I TRY TO FORMAT IT.
  • Anonymous Jan 15, 2009
    I have the same problem. Please help. I can't even take backup of my data. It's not allowing.
  • Anonymous Apr 03, 2009
    Helppppppppppppppppppppppppppp...
  • Anonymous Apr 09, 2009
    TRANSCEND PEN DRIVE - WRITE PROTECTION DELAYED - REMOVE WRITE PROTECTION" problem, and notify you when a new solution is offered.
  • sheiger May 11, 2010
    Hello I am Sheigery.
    I bought an 8GB Pen drive and I am not able tp proceed after 1.96 Gb, when I am prompted with a message that the Write Protection should be removed. How do I proceed and remove the Write Protection ??
    Pla give me your guidance in this matter
    Regards:
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter...
note that the data on the pen drive will be erased. so back it up before you run it.
  • 1 week ago
Posted on Nov 21, 2008
  • bremy Jan 04, 2011
    Perfect Solution....!!!
Hi Pls help me. I have bought anApacer Pen drive. If it exceeds this, there is a pop up of write delayed and remove write protection. In fact it is not write protected. But how can I remove all this and use my pen drive normally
Posted on Nov 28, 2008
My transcend 8 gb flash is detecting but not showing its data
Posted on Apr 21, 2009
Dosent delet or format pendrive
Posted on Jan 11, 2010
    Scholar:
  • 35 Answers
Hey Sanjay,
In order to fix your drive, first we need to know File System you use on this drive and number of files you have in the root folder of your flash drive.Also, version of operating system will help a lot.
First of all, you need to format your Flash Drive using FAT32 file system after backing up your data.
Also, if you are trying to copy large number of files then it could be the cause. Since , there are particular number of files that can be placed in any root  directory.
To take care of this, whenever you are not able to transfer a file after transferring few, simply delete the last 2 files, create a new folder and transfer the remaining files insid this New Folder.
Note: In order to format a Flash Drive use HP Disc Utility. It works on nearly all Flash Drives. Just remember to select FAT32 as a File System.
Here's the link to download HP Disc Utility - -
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
Kinfly respond if you have any further questions.
Posted on Oct 02, 2008
    New Friend:
  • 6 Answers
1) GO HERE
2) select your drive
3) use JetFlash Online format or download Autoformat
use AUTO FORMAT 2 optimize format it !!!!!!!!
Posted on Nov 12, 2012
SOURCE:
My 8gb transcend is write protected ..how to remove it
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Jul 20, 2010 | Transcend (589307) Media
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write protected
do you use windows vista or windows 7 OS?
They have a feature to use an external pen drive as a virtual system memory.
Try backing up all your data to your hard drive then full formatting it choosing NTFS system.
If you use OS which are older than Win XP, you need to format it in FAT32 system instead.
Hope this helps.
Sep 09, 2009 | Sony Electronics - Others
Remove Write protection from the Pen drive permanently
Hi Abhishek,
There is a samll tab in the which will have lock mark, move it to unlock.
That will remove the write proterction, still have issue replace the drive.
Thanks
Smith
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Electronics - Others Logo
10,183 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
