Printers Logo
Problem with Canon Printers
Reset Waste INk Canon MX318
My Printer Canon MX318, wast full waste ink absorber and need code for reset, help Me
Posted by avatar on Sep 16, 2008
    • By avataralfa_centrin Sep 16, 2008
    • Regard,\
      thanks for your solution but on Canon MX318, I am not found 'RESUME" button, but only "POWER, COPY, FAX, SCAN, STOP/RESET" Button and other button, which one is same with RESUME Button. thanks
    • Dear Fixya
      Thanks for you solution, this is very best solution!
      thanks ..... 2000 x
      Remarks :
      Resume Button replace with Stop/Reset button
Solutions (6)
Best Solution
help me please....!!
may printer error 5B00
error 5b00 is wasted ink tank full....
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Thanks for using Fixya
SAM ANDERSON
check printer 5B00
help me to make it better please, the solution did not work ......
  • By Author imagedellaya Dec 16, 2009
waste ink counter reset for canon pixma mp190 photo all in one
check printer problem 5b00
Add Your Solution
