Question about Microsoft Sharp Kin 2 Standard Battery 1100 mAh
My Kin Two died, and now it won't charge. It was working fine yesterday, and I used it normally today. The battery died about 10 minutes before I tried to charge it, which is not uncommon. When I plug it in, the screen remains black, then briefly shows the "beginning to charge" screen, then goes black again.
    Master:
  • 691 Answers
Look at your charger connection and plug and make sure they are clean of dust/dirt...etc.
Posted on Nov 30, 2017
Cory5468
  • 125 Answers
SOURCE: Microsoft Zune 30gb black battery/charge problem
When the battery turns green, take it out so it doesn't drain.
Posted on Apr 12, 2008
SOURCE: My zune wont properly start up
Suggestion #1.
Suggestion #2.
Suggestion #3.
Try them, 1, 2, 3.
Posted on Mar 08, 2009
  • 3 Answers
SOURCE: ZUNE NOT WORKING! ONLY BLACK SCREEN! WONT CHARGE!
Listen everyone this is what happened to me and what I did. Let the battery drain completely (unplugged from computer). It usually takes 5 to 6 hours to drain completely.
Then plug back in and hold the back and down button at the same time. Zune should resume functioning afterwards. All that is needed is a recharge.
Posted on May 13, 2009
SOURCE: shows full charge but dies within one song
You have drained your battery, most likely from charging it when it did not need to be charged, or by leaving it on the charger for way to long.
If that IS the case, you need to either void all warrentys you may have, and take the zune a part, and replace the battery.
Or you have to buy a new one.
I had the same problem, but mine was still under the 1 year microsoft warrenty, so i got it replaced.
Maybe you could do the same.
Have a nice day.
Posted on May 30, 2009
SOURCE: black screen on zune, computer will not recognize it
I know that it sucks but you'll have to return it, I tried to find a solution ( I have the same problem:my screen go black when I turn it on) I din't find any solution that work.That's what I did, I returned it :(
Posted on Jun 14, 2009
2006 Jetta 2.5 battery died, jumped car, radio won't turn on
Take it in to have a charge system check done on it, Your alternator is probally shot,
Nov 27, 2012 | Cars & Trucks
2004 mustang won't start because of anti theft system
Did you check the battery of the car (maybe loose cable)? but if it just happen suddenly, it might be your altenator that wasn't charging your battery. I think once there's enough power gone through the car then your anti-theft system should work as normal again.
Sep 28, 2012 | 2004 Ford Mustang V6
Kin one won't turn on
that is a good indication that the battery needs replaced . we do not do that but perhaps a computer repair shop can /will
Dec 02, 2017 | Microsoft KIN One Cell Phone
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
My phone turned off yesterday n now won't turn back on at all. What do I do I need to use it today
Try these few simple steps.
1. Remove battery.
2. Wait 30 seconds then replace battery
3. Plug in your phone charger.
4. Leave for 10 minutes.
Now try to switch on your phone.
If it doesn't switch on, take back to where it was purchased.
It may just be a charger problem but it could also be charger port or phone hardware.
Jun 17, 2011 | HTC Desire Cell Phone
The battery died on my 2003 Chevy Monte Carlo and after the first time I jumped it and drove it around a little to try and charge the battery, the Security light came on. After I parked it and turned it...
Im pretty knowledgable in the whole SECURITY light issue... I dont think this could cause the door lock to not work correctly, but anything is possible. Newer cars are wound up pretty tight. Here is a link to help understand how the security works.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
I'd go ahead and do a "security relearn" on you car. It might help if that is what caused the door issue.
Turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) Turn back your key to regular position and check the door lock. May have to do this process 3x
Jun 13, 2011 | 2003 Chevrolet Monte Carlo
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
Microsoft Sharp Kin 2 Standard Battery 1100 mAh Logo
363 people viewed this question
Top Microsoft Electronics - Others Experts
Marvin
Marvin
Are you a Microsoft Electronics - Other Expert? Answer questions, earn points and help others
